2018 Prius Prime
Discussion in 'Prime Main Forum (2017-2022)' started by JGC61, Aug 11, 2017.
  1. Alan Winston
    Alan Winston Junior Member
    38
    30
    Seattle
    Per What Light Wave Do Solar Panels Use? 7% of the available energy is in the visible part of the spectrum. If the cells are highly effective at capturing energy in infrared and ultraviolet, and transmit most of the visible, then you would have high visibility and high electrical output.
    pilotgrrl and CharlesH like this.
  2. seattlite
    seattlite Junior Member
    16
    Auburn, WA
    Any new news on the 2018 Prime? Wondering if I should just get a deal on a 2017 or wait for a 2018 with added features.
    #22 seattlite, Sep 11, 2017
  3. Husker4theSpurs
    Husker4theSpurs Active Member
    656
    128
    Papillion, Nebraska
    I think the general consensus is that a mostly complete carryover is likely for 2018. I would imagine deals like we are seeing now are the lowest we'll ever see.
    bps likes this.
  4. Mark57
    2,945
    2,740
    OK
    I would suspect different color choices to be the only change. That's what we've seen in each of the groups (generations).
  5. bps
    bps Active Member
    304
    119
    I agree -- there’s a very high likelihood that it will just be a carry-over year with a $xxx price increase. (Probably in the neighborhood of $500.)
  6. wenglish
    wenglish Junior Member
    17
    Seattle burbs
    I'd been holding out for a 2018 Prime to make sure I get the most "modern" features since it will be 5-10 years before I buy again.
    In light of the above (no changes expected for 2018), can anyone give a quick comparison of the 2017 Prius Prime vs. the 2018 Camry Hybrid LE with respect to the techy side of things (safety features primarily)?
    I know the 2018 Camry is on the new architecture (TNGA?). Is the 2017 Prime also on that new architecture? If not, what would I be missing by buying the Prime vs. the Camry Hybrid (again with respect to techy-type stuff).
    Thanks.
  7. Mark57
    2,945
    2,740
    OK
    Entune 3.0 is one of the biggest new features on the 2018 Camry but look at the trim levels closely. It's all available on the Toyota site for you to read.
    priifamily likes this.
  8. jaqueh
    jaqueh Active Member
    341
    199
    San Francisco
    They are both TNGA but the Camry still has better handling as it doesn’t have a big battery high above the ground, has better wheels, and has wider tires. It’s also faster 0-60.
    Huge difference though is that the Camry will never plug in. So the choice is up to you. Entune 2.0 vs 3.0 are both garbage from everything I’ve seen.
  9. CharlesH
    2,798
    1,166
    Roseville, CA
    Isn't one of the main "features" of Entune 3.0 that it upgrades the Safety Connect cell phone so that Entune media apps can use it, instead of them relying on the user's smart phone's Internet service? And creates a WiFi hotspot. In the current version, the Safety Connect cell phone is used only for telematics like remote A/C, charge management, car locator, and emergency response in case of an accident. Same old apps with Entune 3.0 (no Apple Play or Android Play).
  10. Jawsch
    Jawsch Member
    34
    57
    Lexington, KY
    All Prius models are TNGA
  11. bisco
    52,849
    really? c and v?
  12. Tideland Prius
    16,680
    No. Just G4 and Prime for now. (and it's just the chassis)
  13. wenglish
    17
    Seattle burbs
    Thanks everyone for the responses about '18 Camry vs. Prime. We stopped at the dealer this weekend, and while I really really wanted the Prime, it's just not for us, primarily (pun) due to the smaller trunk space compared to the Prius, which is to be expected - they have to put the extra batteries somewhere.
    Mark57 and jaqueh like this.
  14. RonMc5
    RonMc5 Member
    89
    73
    Santee
    Perhaps not the AC, but at least the fan, with "flow through" set so it doesn't accumulate an excess of heat. The car can set the "flow through" already. I believe the solar panels on an earlier (US) Prius did exactly that unless I am mistaken. :)
  15. bisco
    52,849
    true, but you don't need a thousand dollars worth of solar panels to do that.
    RonMc5 likes this.
  16. ml888
    ml888 Member
    50
    29
    New Jersey
    I'm hoping for LED interior light. Even my 6-yo vehicle without LED headlights has LED interior light to give a focused, brighter light that's easier for reading and less distracting for driver. I really don't know why Toyota decided to not use LED for interior lights ...
  17. VTBIGDOG
    VTBIGDOG Active Member
    211
    146
    For less than $9 including shipping you can buy a kit on eBay that includes LED replacements
    pilotgrrl and kenoarto like this.
  18. ml888
    ml888 Member
    50
    29
    New Jersey
    Do you have a link and/or Youtube video? It sounds like one has to buy some pry tool too? I'd like to follow some clear instructions closely to avoid breaking covers etc. I've seen some for Prius dome light replacement but not for Prime. Also my older car has two dome lights one for each side, Prime has only one, which means it can't be focused light even after replacement. It's a small thing but Toyota should've thought of it.
  19. patentcad
    patentcad Junior Member
    24
    Chester, NY
    It won't, wipers like flat surfaces, the Prime rear window is a valley.
  20. Tideland Prius
    16,680
    Flatblade screwdriver works (use a tissue if you're afraid of scratching the plastics.
