2018 Prius, second 12V battery just died. What's going on?
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Halcykon, Apr 12, 2020.
  1. Halcykon
    Halcykon Junior Member
    35
    Sugarland
    2018 Prius
    I'm not sure if I just happened to get two defective batteries, but both times, my 12V battery died after a two week period of no driving.
    The first time I was overseas for two weeks and came back to a completely dead 12V. That battery was about a year old. The dealership replaced it with another 12V.
    The new battery just died today. 6 months old. I drove 55 miles two weeks ago, and didn't drive it for the past two weeks.
    What's going on?
    • Am I just unlucky and was given two defective batteries?
    • How would I check if my car is drawing more power than normal? I turn everything off. Maybe the USB cables I leave in the car is drawing power? (unlikely)
    • I'm thinking about getting a trickle charger or small automatic tender type 12 V battery charger. Any thoughts on those?
    I'm at a loss here, and I'm concerned that this is going to be an ongoing problem for my car...
  2. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,530
    Bay Area, California
    2019 Prius Prime
    Welcome to Prius Chat(y).
    Some questions:
    • Where did you buy the battery at?
    • Any after market accessories on your Prius?
    • Any warranty from the store you bought the battery at?
    • How frequently are you turning your car on and how long do you let it run for?
    Good luck and keep us posted(y).
  3. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    You said "I drove 55 miles two weeks ago" - how long before that was it that you drove? I've heard of a few batteries in various cars which have gone flat due to COVID-19-lockdown.
    amos likes this.
  4. FuelMiser
    FuelMiser Senior Member
    1,349
    929
    Monument, CO
    "Defective" can only be determined by putting the battery on an analyzer found at battery shops. Surprising that a new-ish battery cannot be reconditioned, again by a battery shop. Dealerships are in the business of selling replacement parts, not reconditioning existing ones. I would definitely buy a trickle charger in your case when you're not driving the car much.
  5. bisco
    52,883
    check the load when it's off. you can shut off sks while away
  6. alanclarkeau
    7,045
    7,593
    I wonder if there might be something else drawing current. I assume you don't have a DashCam or similar which runs 24hrs/day?
    There was talk a couple of years ago about someone who bought a PRIUS and it had some monitoring/security gadget installed by the dealer for while it's sitting in the Dealer's yard - which they'd forgotten to remove.
  7. Halcykon
    35
    Sugarland
    2018 Prius
    How do I check the load when it's off? And is there a way to turn off the sks without going to the dealership to do it?
  8. Halcykon
    35
    Sugarland
    2018 Prius
    I do have a dashcam that turns off when the car is off. Now that you mention it, I wonder if it draws power when I have the car off. I also have two USB cables plugged in.
    How would I go about asking if there's some sort of monitoring gadget on the car? This is a good point though.
  9. bisco
    52,883
    idk how to measure the load. if no one here can help, there are other 12v threads with information.
    check your manual, i believe gen 4 sks can be shut off with the fob.
  10. Mendel Leisk
    42,368
  11. CooCooCaChoo
    CooCooCaChoo Senior Member
    962
    544
    Cow-lee-fornia
    2023 Prius
    Yeah, even if you are locked down due to the epidemic, should at least go sit in the car with it turned on for 20 minutes so the 12v doesn't die.
    I drive my 2017 every other day for about 20 minutes going to the grocery store.
