2018 Prius Temperature Warning Light turning on
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Dharma1212, Mar 27, 2024.
  1. Dharma1212
    Dharma1212 New Member
    Lakewood
    2018 Prius
    Recently I noticed that when I am driving to work in the morning and I have the heater/defrost on my temperature warning light will turn on when I come to a stop and disappear as soon as I start driving. I took it to the dealership for 100k maintenance and asked them to check if I had a coolant issue related to this. They said they were not able to find any leaks and my coolant is full. I had them test drive with the heater on and they said they did not see the light come on. I was reassured everything seemed fine but then two days later the light reappeared when I was on my way to work. I am worried I am messing up my engine and am not sure what else could be wrong.
    52,818
    did they run a scan for trouble codes?
  3. ChapmanF
    18,999
    Temperature that goes high only when the car is stopped may suggest a problem with the cooling fans behind the radiator.
    Once the car is moving, the relative wind moves enough air through the radiator to cool it without the fans.
    Dharma1212, Doug McC and FuelMiser like this.
  4. Dharma1212
    Lakewood
    2018 Prius
    I think they did but they said they couldn’t recreate the issue and cause the light to come on
  5. Dharma1212
    Lakewood
    2018 Prius
    I was driving this morning no heater or defrost on and it sadly came on again so I don’t think the issue is related there. The dash temperature read 55 degrees Fahrenheit and it does seem like this issue is restricted to the morning when it’s cold
  6. Mendel Leisk
    42,315
    How the coolant level, in the engine reservoir, under the hood?
  7. Dharma1212
    Lakewood
    2018 Prius
    I checked and it’s full, they made sure it was full when I was at the dealership last week as well
  8. Rwc86
    Rwc86 New Member
    London England
    On the generation 4s, there’s a coolant temperature sensor above where the exhaust manifold is. I’ve repaired 4 cars where the wires have broken directly at the sensor plug. It will cause the high temperature light to come on, and on the diagnostic system I was using it threw out no codes. The light was on even when the engine was cold and freshly started. It’s worth taking a few moments to check if that might be your issue too
