2018 Prius: Touring vs. No-touring
Discussion in 'Gen 4 Prius Main Forum' started by DrMetal, Mar 10, 2018.
  1. DrMetal
    DrMetal Junior Member
    37
    Silver Spring, MD
    I'm going to buy a 2018 Prius, was contemplating Touring vs. no-touring.
    Aside from the physical exterior differences between the two, what's the difference? Is it that the Touring 'handles' more like a sports car?
    Do the tires on the Touring wear down faster? [this is a big concern for me, because I drive a lot.] If that's the case, then I'll likely avoid the Touring.
  2. Tideland Prius
    16,680
    The suspension tuning is different (the spring rates are higher in the Touring and I think there are different bushings). Of course the 17" wheel and tire combo will add to the handling capability.
    If you drive a lot and tire replacement cost is a decent part of your budget, 15" tires will always been cheaper than 17" tires. (and yes lower profile tires on the 17" will typically wear faster than the higher profile tires of the 15" set if they are the exact same brand and model of tire)
    Mendel Leisk and RCO like this.
  3. DrMetal
    37
    Silver Spring, MD
    Thank you, that's what I thought. I think I'll pass on the touring
  4. Mendel Leisk
    42,345
    Mpg tends to take a hit too, with Touring. Personally I'm not impressed with 4th gen 17" rim appearance, it's colour, and all the plastic bits.
  5. DrMetal
    37
    Silver Spring, MD
    I had no idea. That's an even better reason to avoid the touring option!
  6. Mendel Leisk
    42,345
    Our 2010 has the 17", and you can see from Fuelly badge it's not terrible, but it's acknowledged there's a "hit". I mainly just couldn't stomach the 15" wheel covers. Also, in 2010 at least there was some mechanical differences in the steering: we test drove both a 15" and 17" model, and with the latter I instantly felt "at home", the steering felt planted. The 15" had a more "vague" feel.
    It's not just the wheels either: in winter we swap over to 15" X-Ice, and I don't notice a difference in steering feel, just a cushier ride, lol.
    My understanding is that this variation is no longer the case though. If possible, maybe test drive both, to see for yourself, with 4th gen.
    RCO likes this.
  7. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    It's the balance, the 17" are what all the Press cars are, to give a good impression of driving characteristics.
    Someone posted only in the last few days that he got rid of his 15" ECO tyres and put performance tyres on instead - then said "The car handles MUCH better, though, than it did before. I think it’s worth the trade-off. With the stock LRR tires, the car got skittish when cornering at speed or under acceleration. That problem has disappeared with the new tires." But - he lost what looks like 10-15% efficiency.
    Drive the 2 - see which you like best. Here, it's not such a difficult decision, as the 17" tyre version is an extra $8,000 - nope.
    RCO likes this.
  8. Prodigyplace
    12,712
    11,848
    Central Virginia
    The tire brands vary on each individual 15" tire car, likely dependent on factory stock. There are other suspension enhancements that can help increase handling performance, usually without taking an mpg hit.
    @sfv41901 and others can advise further.
  9. Mendel Leisk
    42,345
    I wonder if he (or she) is just trying to justify the upgrade. I notice no difference, apart from cushier ride with the 15", compared to stock 215/45R17 Michelin Pilot MXM4 on stock 3rd gen rims. I did notice a difference, driving a 2010 that came stock with 15" rims. If there's still differences, I'd suspect it due to different steering ratio, mechanics whatever.
    RCO likes this.
  10. Tideland Prius
    16,680
    The Gen 4's Touring setup is quite firm (that's what we have). I believe the gear ratio and electric motors are the same between the two models for Gen 4.
    RCO and Mendel Leisk like this.
  11. Mendel Leisk
    42,345
    Firmer suspension then? Some of it might be the low profile tires too, they tend to rattle fillings a bit more.
    RCO likes this.
  12. Tideland Prius
    16,680
    Yes the Touring definitely has a firmer suspension. I asked and the response was higher spring rates and Touring-specific bushings.
  13. alanclarkeau
    7,045
    7,593
    Definitely rougher ride. On my short list when I bought PRIUS were a few cars which, if you bought the "top of the line" model with all the extras - you HAD TO take the fat, low profile tyres. In at least 2 cases, that absolutely ruined the car, though it did handle better.
    But crazy idea - but marketing guys seem to know what people want, but they don't seem to ask the actual potential purchasers. The trouble was, the demographic for the cars was >50 yr old or even older - who would prefer a car which was quiet, smooth, but with all the gizmos, even if it didn't handle like a Ferrari.
  14. Mendel Leisk
    42,345
    I'd like quiet, smooth, Ferrari handling not required. All the gizmos? Drop-kick 'em off the driveway. Edgy, edgy styling, which equals insane repair costs: punt away too.
    RCO likes this.
