2018 Prius TWO
Discussion in 'Gen 4 Prius Technical Discussion' started by Ali_A, Oct 26, 2021.
  1. Ali_A
    Ali_A New Member
    NC
    2019 Prius
    I have recently purchased 2018 Prius TWO.
    Very smooth ride, however when I accelerate from stop or low speed I hear tuk sound coming from under the engine.
    I took it to my mechanic, when he lift up the vehicle and manually spin the wheels we could hear the sound coming from inside the transmission. He said this is likely to be a normal sound (I do not think that's true).
    Has anyone had similar issue, what are the possible causes?
    Thanks
  2. vvillovv
    vvillovv Senior Member
    4,337
    1,519
    NY
    Might be the inner CV joint on the drivers side drive shaft. That is close to the tranny.
    And if one of the 4 CV joints is going bad - they do / it does - make the thunk during acceleration and other times too, when getting in even worse shape.
