2018 Rav4 Hybrid or 2017 Prius v
Discussion in 'Prius v Main Forum' started by Orion Antares, Jan 20, 2021.
  1. Orion Antares
    Orion Antares Junior Member
    Wisconsin
    We're looking to replace our current Prius v with much lower mileage vehicle. We say two good options in a 2018 Rav4 Hybrid with 13k miles and a 2017 Prius v with 44k miles similarly equiped.
    My question is if anyone had any opinions on which might be a better option from a mechanical stand point? If there are issues worth consider that would make one more favorable over the other? I'm still looking through some of the Rav4 hybrid info at this point as well as if there are any noticeable changes with the 2017 verse the 2013 v.
    52,789
    both great cars, i would go with the one that best suits your needs.
    v has the egr/ head gasket issue, rav 4 has the fueling issue, but there may be a remedy.
  3. rjparker
    rjparker Tu Humilde Sirviente
    11,015
    6,903
    Texas Hill Country
    You upgrade to a much better 2.5L with the 2018 Rav4 hybrid while the 2017 Prius v remains the problematic 3rd gen 1.8L. 2018 Rav 4 hybrids also had awd.
    The 2017 v had better pistons and rings than the 2013 v and better crash tests.
    The 2018 Rav4 hybrid was the last year before the 2019 redesign.
    All 2018 Rav4s hybrids had automatic emergency braking, forward collision warning, pedestrian detection, lane departure warning with steering assist and automatic high beams. Higher trims had Blind-spot warning with rear cross-traffic alerts standard. Blind spot was optional on the Rav4 XLE hybrid. A0B345F0-9EE1-4983-9A07-E678D4B50A85.jpeg
    #3 rjparker, Jan 20, 2021
    Misplaced10mm and Tideland Prius like this.
  4. Orion Antares
    Wisconsin
    Is that fuel tank issue on the 2018 models or is that a 2019-2020 model issue?
  5. bisco
    52,789
    sorry, i don't know the answer to that. i have read about it, but not noted the model year(s)
  6. rjparker
    11,015
    6,903
    Texas Hill Country
  7. Aaron Vitolins
    Aaron Vitolins Senior Member
    1,612
    1,145
    Franklin TN
    Unless you need AWD, I’d do with the V because the 1st gen rav4 hybrid isn’t super efficient.
    I would get the v and add a oil catch can like many do, to slow, or maybe prevent the egr system clogging up, and change the engine coolant at 50k since its 4 years old. Just my two cents, take it or leave it! Like both of them, wishing you the best.
    Georgina Rudkus likes this.
