2019-2020 Prime brake assist recall
Discussion in 'Prime Main Forum (2017-2022)' started by mistermojorizin, Aug 16, 2019.
  1. mistermojorizin
    mistermojorizin Active Member
    310
    137
    usa
    2019 Prius Prime
    2019 TOYOTA PRIUS PRIME | NHTSA
    Toyota Motor Engineering & Manufacturing (Toyota) is recalling certain 2019 Lexus LS500, LC500, ES300h, UX250h, LS500h, Toyota Prius, RAV4 HV, 2019-2020 Toyota Prius Prime, and 2020 Corolla HV vehicles. The brake booster pump may fail causing a deactivation of the Vehicle Stability Control system and a loss of braking assist. As such, these vehicles fail to comply with the requirements of Federal Motor Vehicle Safety Standard (FMVSS) number 126, "Electronic Stability Control Systems."
    GTprii likes this.
    52,862
    the hits just keep on coming
  3. Montgomery
    Montgomery Senior Member
    2,254
    2,244
    Orange County, CA
    I saw this yesterday. Man, Toyota needs to step it up with it's 3rd party vendors. This is going to cost them.
    52,862
    i wonder if the brake components are too complicated to successfully mass produce?
    Montgomery likes this.
  5. Montgomery
    2,254
    2,244
    Orange County, CA
    Good question. My 2015 hasn't been hit with any recall issues that I am aware of yet. I hope it stays that way.
    GTprii likes this.
  6. mistermojorizin
    310
    137
    usa
    2019 Prius Prime
    I wonder why it started with the 2019 generation of hybrids and lexus non-hybrids.They've been making the Gen4 since 2016MY. It's not like it's a new design. Wonder what changed?
  7. bisco
    52,862
    just a bad run maybe
    Trollbait likes this.
  8. Trollbait
    12,831
    Brake booster pumps have been used in diesels for as long as diesels have had power boosted brakes. The pumps and accumilators are also in turbocharged gas engines.
  9. ChapmanF
    19,033
    From RMISC-19V544-8456.pdf linked on the NHTSA page:
    and as to the cause:
  10. PT Guy
    PT Guy Senior Member
    1,085
    713
    Washington, the state
    Maybe a different supplier.
  11. will the engineer
    will the engineer Active Member
    238
    119
    LA
    2019 Prius Prime
    welp time to take in my vehicle
  12. ChapmanF
    19,033
    Hmm, I guess they did give a production date range for the cars. I overlooked it the first time.
  13. ctscoob
    ctscoob Junior Member
    56
    36
    CT
    2020 Prius Prime
    My ‘20 isn’t part of the recall. You can plug your VIN in on that site above to see if you’re affected.
  14. mistermojorizin
    310
    137
    usa
    2019 Prius Prime
    when you put your vin in, does the recall come up for you on the nhtsa site?
  15. m8547
    m8547 Senior Member
    951
    631
    Colorado
    2018 Prius Prime
    The 4runner has had an electric brake booster since 2003, I think. It is surprisingly reliable even though it seems like it wouldn't be. But if it fails it's really bad (can lose power brakes) and really expensive to replace ($700 used or $2000+ new).
  16. ChapmanF
    19,033
    My first car didn't even have power brakes to lose. My next two did, but they were vacuum-based and could only give you maybe two or three banked-up brake strokes if the engine stalled and stopped pulling vacuum, and they had no warning beep.
    The electric-pumped accumulator in the Prius holds enough fluid under pressure for around thirty uses of the brake with full power assist if the pump stops working ... and for the last ten or fifteen of those, you'll have the infernal beeping to warn you that something's not right.
    Curlyone likes this.
  17. Montgomery
    2,254
    2,244
    Orange County, CA
    I didn't know that. This is good to know.
  18. Trollbait
    12,831
    Never counted them in the turbo Sonic, but had far more powered brake applications without engine power than the one or two in a naturally aspirated car.
  19. Salamander_King
    Salamander_King Senior Member
    11,024
    8,980
    New England
    Trying to set up a new service record data on the DriverSide page, I just noticed there is a safety recall on 2020 Prius Prime. I checked at NHTSA site, but my 2020 Prime LE was not affected. The recall was already out last year 2019-07-24, I wonder how many 2020 models were affected?
  20. digitalundertaker
    digitalundertaker Junior Member
    17
    Sacramento, CA
    2020 Prius Prime
    Completely different operation. Break booster on hybrids can't rely on vacuum from the engine, at least Toyota. By the way those hydroboosters in Ford and dodge diesels are completely crap.
