Featured 2019 Ford Escape to get plug-in hybrid, plus Expedition SUV hybrid, Lincoln versions too: report
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by Tideland Prius, Nov 24, 2017.
  1. hill
    8,810
    one could make the same limited rationale about the Prius Prime .... and just leave it as a hybrid. Yet owners find the benefits much more favorable than the former. Matters not - SUV, or minivan, they are both about the same weight when adding 12-14kWh's to the mix. Not only do we get insane efficiency with the plugin minivan;
    We get better efficiency than many Prius owners. Only difference, is we can haul 8' ladders, drywall sheets, plywood sheets, with plenty of room to spare, not to mention all of the camping possibilities.
    Compare that to our Lexus SUV hybrid? Relatively same heavy chassis & area for batteries? You are only talking 28 MPG epa. Compare that to the Pacifica plug-in, well, it's been a ½ year & we've finally polished off it's 1st tank of gas. From now on, unless we drive out of the state again, we'll only fill up ½way, so the gas doesn't get stale.
    #41 hill, Apr 3, 2019
    bwilson4web and Mendel Leisk like this.
  2. Salamander_King
    Salamander_King Senior Member
    11,019
    8,954
    New England
    Just curious, what kind of mpg do you get from Pacifica plug-in if you do not plug-in. Do you get better than 28 mpg???
  3. hill
    8,810
    Blended EPA is 33 - 34mpg .... ~18-20% higher than our RX
    Salamander_King likes this.
  4. Salamander_King
    11,019
    8,954
    New England
    That's really good for a car that size. If Sienna came in Plug-in I would have been all over it.
    hill likes this.
  5. Trollbait
    12,543
  6. Prashanta
    Prashanta Active Member
    292
    242
    Technology
    Tesla talking points.
  7. bisco
    51,966
    exactly
  8. bisco
    51,966
    so... this should have been out last fall?(n)
  9. Tideland Prius
    16,559
    Lol. I guess?
  10. hill
    8,810
    don't worry, there's no way it can take as long as the Outlander plug-in took to get here.
    Tideland Prius likes this.
  11. hill
    8,810
    maybe I missed it, the liquid cooling, but I did check through the spec sheet. Is the 14 kwh usable? or counting the bottom & top end buffers
  12. Trollbait
    12,543
    According to a report from 2017, which may have confused a 2019 release date for the model year. A more current report from April 2018 reported the redesign would debut in the second half of 2019.
    Ford plans redesign for Expedition, Escape; adds hybrids
    No mention of what the figure entailed where I saw it.
  13. Tideland Prius
    16,559
    I don't think so.
    However, it's gonna suck in Canada - The cutoff for the bigger EV incentive is 15kWh... this is just shy of that.
  14. hill
    8,810
    Maybe Toyota is following the Musk plan .... pick a date & add a couple years.
  15. Trollbait
    12,543
    You mean Ford;)
    I think the original article author got confused over release dates and US model years.
  16. Rmay635703
    Rmay635703 Senior Member
    2,669
    1,688
    Somewhere in Wisconsin
    2013 Chevy Volt
    I completely missed this thread and accidentally am cross posting
    anyway 2019 is becoming 2020 and Ford yet again is teasing a PHEV
    https://www.google.com/amp/s/insideevs.com/news/370087/ford-escape-hybrid-phev-to-follow/amp/
    Says coming soon, matches up to the Mitsubishi PHEV
    Oh and a 48v plug in would not be stupid,
    I have a car that goes 45mph on 48 volts.
    A big 48v battery and systems would be an order of magnitude cheaper than an HV system but would drive the battery to be right on top of the motor along with heavier (more expensive) motor inverter. My guess is the advantages of low voltage equipment even cost could outweigh disadvantages in the case that you want a low speed EV with a high speed gas propulsion.
    In the case of a large vehicle where highway EV range would be abysmal this could drive the EV use case to where its most efficient.
    #56 Rmay635703, Nov 2, 2019
  17. Trollbait
    12,543
    Source article for the OP one.
    Ford will ease into EVs
    It states the new Escape was going to be released in 2019, and the next model year are regularly released in the current year.
    I think the bit about the Navigator, MKC, and Expedition was misdirection from Ford. In 2017, Lincoln didn't have a model based on the Explorer, and plans for the new Explorer, like being RWD, weren't known.
    The 2020 Escape, Explorer, and Aviator are up on their respective websites, with hybrid options. A near by dealer even has one Escape hybrid listed in inventory. The plug in models just won't be available until the actual 2020.
