2019 model will have a normal backseat
Discussion in 'Prime Main Forum (2017-2022)' started by gattaiolo, Nov 24, 2018.
  1. Tideland Prius
    16,680
    :eek:
  2. Rmay635703
    Rmay635703 Senior Member
    2,701
    1,729
    Somewhere in Wisconsin
    2013 Chevy Volt
    Toyota can’t glue the 18lb semi flexible solar panel to the roof sheet metal because the car will fail crash testing .
    52,848
    sorry, i must be losing it. hasn't anyone posted 5 seats coming to the usa?
  4. Tideland Prius
    16,680
    Are you talking about that rumour way back in 2017 when Danny went to Japan to test drive the Prime and someone asked the engineer there.l about a 5-seat version?
  5. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    Skip the soalr panel roof, just give me a socket to plug in my own panel on my garage roof.
    fuzzy1 likes this.
  6. bisco
    52,848
    no, i guess i'm talking about your post number 5. i thought you were confirming the o/p, my mistake.
  7. Tideland Prius
    16,680
    Ohh I see. No. I was just simply responding to the OP's remark.
  8. Rmay635703
    2,701
    1,729
    2013 Chevy Volt
    If they would do that the owner could install the car mounted solar panel just like the owner installs 200 lb roof racks and trailer hitches with zero Toyo liability
    Too bad manufacturers don’t operate that way
  9. bisco
    52,848
    so we don't know anything for sure about the mid cycle refresh?
  10. Trollbait
    12,825
    The PV option isn't just the panel, it is also a NiMH battery that sits under the rear seat. The panel charges that battery, which will then supply the energy to the car when it is turned on.
    The additional weight for the system is enough that buyers in Europe reported that the solar roof wasn't available in the fully loaded trims.
  11. Tideland Prius
    16,680
    Nope :(
