2019 mpg lower
Discussion in 'Prius c Fuel Economy' started by papafern, Aug 27, 2018.
  1. papafern
    papafern Junior Member
    62
    NYC
    2015 Prius c
    Why is the MPG much lower on the redesigned C so much lower than last year's???
  2. PriusCamper
    PriusCamper Senior Member
    13,417
    5,416
    Pacific Northwest, USA
    Can you be more specific? Are you referencing certified MPG on the sticker price on the window, or something else?
    52,793
    lower? it's higher. much higher, percentage wise. you must be thinking of the gen 4 lift back.
    sharp looking, too! and, you get more options in the package.
    looks like a winner!
    #3 bisco, Aug 27, 2018
  4. Prodigyplace
    12,710
    11,848
    Central Virginia
    The 2018 is the same as the 2017. The 2019 EPA mileage is not yet posted. The EPA test changed in 2017, lowering some numbers compared to previous years. That explains this comparison. The testing changed, not the vehicle.
    EDIT: This article says the 2019 Prius c will have the same mileage as the 2017 & 2018.
    2019 Toyota Prius C preview: $900 price increase, fewer options
  5. ztanos
    ztanos All-around Geek!
    3,339
    1,150
    40
    Cumming, Georgia
    The testing models changed. According to Fuelly.com, real world users aren't seeing much difference, if any.
  6. Tideland Prius
    16,673
    @Prodigyplace 's got it. There was a small change to the EPA testing for 2017 that further adjusted the mpg down on all vehicles.
    Prodigyplace likes this.
  7. bisco
    52,793
    i'm still missing the 60mpg my 2004 got.:unsure:
  8. Prodigyplace
    12,710
    11,848
    Central Virginia
    That was imperial gallons, right? ;) Canadian mpg is higher than US.
  9. bisco
    52,793
    i stil have the monroney.:)
  10. papafern
    62
    NYC
    2015 Prius c
    This is what I meant. I have a 2014 so the MPG are higher. I didn't know there was a change in the testing and that's why 2019 is lower.
  11. Prodigyplace
    12,710
    11,848
    Central Virginia
    There was a bit of controversy when Toyota introduced the Gen 4 Prius in 2016. Toyota used the newer EPA test that was not required until 2017 so the mileage improvement looked lower than it really was compared to the Gen 3.
    When everybody else took an EPA mileage hit in 2017, the Prius looked much better since its number did not change.
  12. Tideland Prius
    16,673
    or the Accord Hybrid which had improvements but the 2017 change made the numbers look the same.
  13. papafern
    62
    NYC
    2015 Prius c
    If the camry came in a wagon and hybrid, I would be all over it!!! 50 mpg!!!
  14. bisco
    52,793
  15. Prodigyplace
    12,710
    11,848
    Central Virginia
    You can no longer buy a new one in the US.
    Rmay635703, bisco and ztanos like this.
  16. bisco
    52,793
    have to look for gently used 2017.
  17. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    Either you don't understand this correctly or you just aren't saying it right.
    The "official" EPA numbers are ESTIMATES only and are not even arrived at using actual real world conditions.
    While the published "estimate" for your car might be higher, I'm pretty sure that in practical use it is NOT.
    audiodave likes this.
  18. papafern
    62
    NYC
    2015 Prius c
    The EPA estimate is lower. My 14 has a higher MPG estimate than the 19. Other pointed out that the testing done to get the estimate has changed and that's why there is a difference.
  19. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    That's true I still have the window sticker 60 EPA CITY up to MY2006...2007 2008 2009 had a revised CITY EPA test.
    Car is the same, EPA changes. Meanwhile for a period I was exempt from Va. emissions tests, but the 2007+ had to do it...then they finally fixed it. Glad I escaped the hassle.
  20. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    My sticker says 53 city, 46 hwy, combined 50. As you can see below, I hit that almost exactly.
