2019 Prius LE - Needs Engine Replaced
Discussion in 'Gen 4 Prius Main Forum' started by Willl, Feb 12, 2021.
  1. Willl
    Willl Junior Member
    34
    Orlando
    Need to replace the engine in a 2019 Prius LE. 190k miles Blown head gasket, coolant in cylinders 1 and 2, rough start on engine, blowing white smoke, and starts overheating after about 10-15 min driving.
    Are all Gen4 engines the same?
    Can I just replace with any used 2016+ engine?
    Do I need to find a "Prius or hybrid specific" mechanic to do the install, or can just any competent mechanic that can swap a regular gas engine do the job?
    amos likes this.
  2. Mendel Leisk
    42,384
    Maybe too many threads going??
    soldierguy, Willl and alanclarkeau like this.
  3. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    Yes
    Yes and the hybrid Corolla engine
    Any competent engine mech that can also pull the battery disconnect switch and check codes.
    You may want to clean the EGR
    moto g power ?
    #3 mjoo, Feb 12, 2021
    amos likes this.
  4. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    No!!! - the HYBRID COROLLA, until recently, only had a GEN 3 PRIUS engine.
    Willl likes this.
  5. Willl
    Willl Junior Member
    34
    Orlando
    So I can replace with any 2016+ Prius engine...
    What years are compatible for the hybrid Corolla engine?
  6. Willl
    Willl Junior Member
    34
    Orlando
    I apologize. I will go back and delete any other ones
  7. alanclarkeau
    7,045
    7,593
    You'll have to check the local market. I know when I test drove my Gen 4 in June 2016, the Corolla Hybrid was only new here - with a Gen 3 Hybrid engine. I think early 2019 we got the upgraded version.
    Do you have a Hybrid specialist in your area - I hear there are a few in USA.
  8. ozmatt
    ozmatt Active Member
    637
    263
    Australia
    That's an impressive amount of miles for a 2019 what do you use it for?
    Why not just get the head gasket done, egr clean and install a catch can
    privilege and Willl like this.
  9. David9962000
    David9962000 Member
    141
    68
    2020 Prius
  10. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    Check his profile. He's in Orlando Florida - other side of the world. Different market.
    Toyota introduced the hybrid Corolla as a 2021 model year in US
    Willl likes this.
  11. Willl
    Willl Junior Member
    34
    Orlando
    I tried to request for my other threads to be deleted, but the mods rejected my requests on both previous threads unfortunately... Is there no way for me to delete on my own?
  12. Willl
    Willl Junior Member
    34
    Orlando
    I purchased from auction "as-is" and unfortunately had already titled into my name before the check engine light and temp sensor came on several days later. Now I'm stuck and need to figure out the best solution fast. I have no idea how long the car was driven while overheating and whether the head is warped.
    I've heard that even if the head gasket is able to be repaired, something can potentially fail again as the engine is over 190k...
    Is there a substantial price difference between swapping with a lower mileage used engine vs repairing the head gasket?
    I'm located in Orlando, FL
  13. ozmatt
    637
    263
    Australia
    Not sure about price difference, for me its easier to do a head gasket than a full engine swap (if rods are not bent which hopefully they wont be!)
    I believe its normally rods that bend on these motors, not the head its self... i could be wrong!
    for me, If the rods are good i would definitely just go ahead and do the gasket on the original motor, obviously not everyone will agree that's just what i would do! then clean the egr and ad a $20 oil catch can while your there to prevent future egr problems which lead to blown head gaskets
    I still struggle to fathom how the thing ended up with that many miles already
    Good luck with it, cheers ..
    Valiant V and amos like this.
  14. alanclarkeau
    7,045
    7,593
    Did you work out if there is a Hybrid specialist in your area - from reading the forum for 5½ yrs, there seem to be some very good specialists in USA - could be worth having a chat with one.
  15. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    #15 mjoo, Feb 14, 2021
  16. Elektroingenieur
    2,515
    3,288
    Three Touring
    No. The Electronic Parts Catalog lists a different part number (19000-37850) for model years 2019 and later.
    An engine from an older fourth-generation (2016–2018) model might work in practice; I haven’t tried it. Since these aren’t identical to the later (2019–) design, however, installing one would violate federal law, unless you repeat the certification testing that Toyota did: see the EPA Tampering Policy (PDF), page 7, Basis A, note v.
    alanclarkeau likes this.
  17. Mendel Leisk
    42,384
    And transplanting a 4th gen engine (any vintage) into a 3rd gen Prius (or Prius v) is completely beyond the pale? (Rhetorical question ;))
  18. Elektroingenieur
    2,515
    3,288
    Three Touring
    Unfortunately, yes: the regulations require a combination of engine, ECM, transaxle, and chassis that has been previously certified. (See my previous posting.)
    alanclarkeau and Mendel Leisk like this.
  19. amos
    amos Active Member
    376
    285
    los angeles
    Did you already clean the egr cooler and valve? Was it a difficult task xompare to the gen 3? I have over 140k on 2016. No issues at all so far
  20. alanclarkeau
    7,045
    7,593
    There was a previous thread - the engine is dead - he said "Blown head gasket, coolant in cylinders 1 and 2".
