2019 Prius Lurching
Discussion in 'Gen 4 Prius Technical Discussion' started by Mae Theo, Dec 3, 2022.
  1. Mae Theo
    Mae Theo New Member
    2019 Prius
    While in a driveway, I was reversing in my Prius but accidently put it in neutral to have the car go into neutral and lurch forward hitting a parked car in the driveway. Though I tried to brake as much as I could it still went forward at 5-10 miles and hour. Has this happened before?
  2. FuelMiser
    FuelMiser Senior Member
    1,349
    929
    Monument, CO
    Doesn't make sense. Neutral disengages the drive, so the car can't lurch. To put the car in Neutral, you have to hold the shift lever to the left for a second or two before it disengages the drive. If you simply push the lever left and release it, the car will still be in gear. If you had been in D (forward gear) and wanted to move to R (left and up), but only went left briefly without holding it there to disengage, then the car would still be in D (forward) and the car could lurch forward. Suggest you practice with the shift lever to learn the behavior.
    BiomedO1 and Harters like this.
  3. BiomedO1
    BiomedO1 Senior Member
    4,633
    2,433
    Left Coast
    Yep, gotta hold the shift lever in the left position for at least 3-5 seconds before Neutral is engaged. I parallel park on a hill and have to curb my tires. It took some getting used to, and my previous car was a Prius C.
    Left Up or Down, pretty much engages immediately.
  4. Elektroingenieur
    2,515
    3,288
    Three Touring
    If I were investigating an incident such as this, I’d check for stored Vehicle Control History events, which could help to identify abnormal shifting operations, such as “Shift N Change by Busy Shift.”
    It’s the driver’s responsibility, however, to do as Toyota recommends in the Owner’s Manual (PDF), page 250: “make sure that the shift position has been changed to the desired position by checking the shift position indicator.” For R⃣, you can also listen for the reverse beep and watch for video from the camera to appear.
  5. vvillovv
    vvillovv Senior Member
    4,337
    1,519
    NY
    there is also a warning message on the MID screen after a missed shift into neutral. It's frustrating to try to comply with the message as the shifter doesn't respond immediately while holding the shifter in the neutral position, it takes a few seconds for the computer to respond as @BiomedO1 explained above.
    It's confusing, especially the first few times it happens.
  6. Andrew Swace
    Andrew Swace New Member
    Sweden
    Probably in neutral and rolled backwards then put it in drive and lurched.
  7. bisco
    52,877
    op was so embarrassed, they didn't come back
  8. a2058
    a2058 Junior Member
    59
    24
    Westchester, NY
    2019 Prius
    XLE AWD-e
    I remember seeing somewhere that this has caused accidents… that once the car is in neutral, you don’t have to press on the brakes to shift back into drive. So if some one was reversing, and then somehow put the car in neutral by mistake or just fiddling on the shifter knob, but still believing that it was in reverse and gave it gas, but it could have been easily put in drive if not familiar with the shifter arrangement, could have been put into drive and then the car would lurch forward. I guess may be that’s the reason for the rather loud back up beeping we have in these cars…
