2019 Prius PHV
Discussion in 'Prime Main Forum (2017-2022)' started by chinito77, Mar 28, 2018.
  1. Rmay635703
    Rmay635703 Senior Member
    2,690
    1,725
    Somewhere in Wisconsin
    2013 Chevy Volt
    You mean the rav 4?
    I thought that one was just for overseas customers
  2. Tideland Prius
    16,677
    Well given that the 2019 Prius may include D-4S and a slight mpg improvement, I suspect the PHV/Prime will get the same engine improvements and the rumoured battery improvements. This could be used to offset the heavier car for 5-passenger seat or it could remain a 4-seater with better acceleration and mpg.
    I'm still hoping for a sub-10 second 0-60mph. Practically all other EVs/BEVs accelerate faster and 10/12 seconds HV/EV is embarrassing (and that's with just the driver - load it up and it'll be more like 12/14 I'm guessing)
    bwilson4web likes this.
  3. goinskiing
    goinskiing Active Member
    202
    187
    Meridian, ID, USA
    2018 Prius Prime
    What do you mean by given? Is it known there will be a change in the 2019? If so, i may hold off until then. Also, whats is the D-4S, is that a battery?
  4. ClemsonSteve
    ClemsonSteve Active Member
    270
    248
    South Carolina
    There will always be a reason to hold off—underscore updates. The one bought in 2019 will be usurped by the 2021 model and so on. I’m glad I went for the awesome deal on the 2017 a month ago—now when I look in my rear view mirror, I no longer see Benjamins $$$ floating out of my car LOL!
    ruby, benagi and bwilson4web like this.
  5. Trollbait
    12,817
    D-4S is a hybrid port and direct injection for the engine. The engines in the new Camry has it, and there is also a new 2.0L hybrid system with it coming. IIRC, going into the Auris and Corolla hybrids.
    Instead of giving the Prius that new system, Toyota will likely just make slight changes to the current 1.8L, like the D-4S
  6. Tideland Prius
    16,677
    The same article with the mock drawings of the 2019 in purple (you may have seen that thread around PC) also mentions the possible changes for the Prius. These changes are likely to make it to the Prime since they share most Hybrid components.
    The 2019 Prius will likely undergo a midlife update. It remains to be seen if the Prime will be updated as well or it will go another’s year before a midlife update.
    Trollbait already mentioned the D4-S system
  7. Trollbait
    12,817
    It is possible the Prime won't get D4-S if the Prius does.
    The Prime is lower volume and buyers mainly choose it over the Prius for the EV side. The new injection system doesn't add to that, and keeping the old is likely lower cost to Toyota.
    Tideland Prius likes this.
  8. jingoro
    jingoro Junior Member
    SoCal
    Any word about the 2019 model yet? Getting close to September...
    priuscatprimeguy and Prashanta like this.
  9. SeattleBicycler
    SeattleBicycler Junior Member
    35
    Seattle
    Word from my dealer is that both new Prius... standard and Prime ... will not arrive at the dealerships until December/January.
    john1701a and Mendel Leisk like this.
  10. ccd
    ccd Junior Member
    socal
  11. Tideland Prius
    16,677
    So that probably means a December production start date and arrival late Dec or early Jan. That matches what @SeattleBicycler said.
  12. schja01
    schja01 Senior Member
    1,868
    1,236
    Chicagoland
    2024 Prius
    Limited AWD-e
    The last sentence of the quoted article says deliveries to begin February 2019.
  13. Tideland Prius
    16,677
    lol. I didn't read the article. I just clicked on the 2nd link and went straight for the table.
    Prodigyplace likes this.
  14. Mendel Leisk
    42,310
    Still depressed, lol. There's a compulsion, to add ever more pointless intricacies and details. Before and after:
    The designers have to have something to show for the paychecks, I suppose.
  15. bisco
    52,812
    designers used to get paid to try and make beautiful appealing cars. i think the mandates are from on high.
  16. Tideland Prius
    16,677
    Well it's not a before and after. The right photo is just a special edition of the Prime. The L-shaped crease matches the one found on the front - helps with unity (tying the front and rear looks together - similar to the Gen 2 Prius). The crease also happens to be found on some supercars. Of course, where the Prime has the indicators and reflectors, on the supercar, those are vents or airflow management areas.
  17. Mendel Leisk
    42,310
    It might be toned down at production then?
  18. bisco
    52,812
    will you buy one if it looks like a hunday?:p
  19. Tideland Prius
    16,677
    Well no. The right one is a production model called the Prius PHV GR Sports and is only available in Japan.
    We don't know what the midlife update of the Prime will look like and what they will do with those lights. Recall that they want to differentiate between the regular Prius and the Prime. But if the 2019 Prius is rumoured to look like the Prime (it'll get the quad LED headlights and the Z taillights will be replaced with a C-shaped one), then the Prime must see a change in the lighting design to keep that gap.
    Prashanta likes this.
  20. Prashanta
    Prashanta Active Member
    292
    242
    Technology
    Have a look at an image of the entire Prime GR. It is actually a very attractive car... most people might say better looking than the regular Prime.
