2019 Prius Prime aftermarket radio Install
Discussion in 'Prime Audio, Electronics, and Infotainment' started by bhol234, Sep 13, 2019.
  1. bhol234
    bhol234 New Member
    2019 Prius Prime
    Hello Priuschat!
    Here is my Install of my Alpine ILX- W650
    Unfortunately the ilx-w650 doesn't have a data link port and cannot read things like tire pressure and engine codes but its still supported and i can control everything from the steering wheel.
    Tomorrow i will upload a video of myself installing this radio into my wife's 2018 prime as well I originally bought 2 JVC KW-M750BT for our cars and the quality was not on par with the ILX -w650
    if you guys have any questions let me know. i know this write up isn't great and im sure ive left some important details out but hey i tried.
    Parts list:
    Metra 40-LX11 Antenna Adapter Cable
    Metra 95-8264HG Mounting Kit
    Maestro HRN-RR-TO2 Harness
    Maestro ADS-MRR Steering Wheel Interface
    Pac USB-TY1 Retention Cable
    Here is the dash kit, it fits perfectly and the gloss black matches quite well
    Here is the Harness you will have to cut off the two end connectors (Grey & White) and wire them.
    This is after wiring everything together with the radios harness (for the antenna connector you will have connect the blue cables together for it to work properly)
    after flashing the maestro i have connected everything together and its ready to be installed into my wifes prime.
    you will need to go to idatalinks website and input your car and type of radio you are installing, they will in return give you a very detailed install sheet to help you.
    upload_2019-9-12_21-30-46.png upload_2019-9-12_21-31-10.png upload_2019-9-12_21-31-18.png upload_2019-9-12_21-35-35.png
    Solar Powered Prime likes this.
  2. Raymond Padron
    Raymond Padron Junior Member
    Norwalk,CA
    How’d you like the radio?
  3. Yamsta
    Yamsta New Member
    Maryland
    Bump, OP wanted to follow-up on how things went? Where is that video? ;)
    Robertnico likes this.
