2019 RAV4 and RAV4 Hybrid
Discussion in 'Toyota Hybrids and EVs' started by Tideland Prius, Mar 28, 2018.
  1. Tideland Prius
    16,683
    lol. They do that in the UK for sports cars - (but then instead of drilling, it ends up on the hood or the top of the bumper instead of the forward-facing part of the bumper)
  2. pilotgrrl
    pilotgrrl Senior Member
    891
    1,797
    Chicagoan in TX
    TX doesn't require stickers on plates.The stickers go on the driver's side windshield, as far down as you can get them.
    Tolling is all open road and red light cameras take pictures of rear plates, which have some interesting holographic features embedded in them. I don't know nefarious purposes LEO uses those for
  3. Prodigyplace
    12,720
    11,852
    Central Virginia
    You have a (big) front sticker though ;)
    pilotgrrl likes this.
  4. Lucifer
    Lucifer Senior Member
    1,014
    486
    Nh
    Actually 31 states require front plates, I'm amazed Tesla doesn't provide a front plate kit, wondering if the holes aren't drilled but the t-nuts are installed for plate bolts.
  5. Tideland Prius
    16,683
    It's interesting that the folks over at RAV4 World didn't already know that the RAV4 Hybrid is the quickest model (Gen 4) given it has 194hp over the standard 176hp and the electric motor torque offsets the extra weight, beating the 172lb-ft (at a pretty low 4,100rpm actually) of the current gen RAV4.
    The biggest improvement on the hybrid (aside from mpg of course) will be the 30% extra power for the rear wheels. The current R4h doesn't have the same capabilities as the gas version. No electronic locking diff and of course a rather weak rear motor. According to Alex on Autos, the power distribution is, at best, 70/30 front/rear for the hybrid. A back-of-the-napkin math of +30% means the power distribution could be 55/45 front/rear. Still can't beat the torque vectoring system on the Gen 5 gas model but at least it can handle something more than just a slippery intersection.
    pilotgrrl and Prodigyplace like this.
  6. Trollbait
    12,832
    Power distribution is only part of the equation. The other is the time that AWD can be sustained. A 55/45 split isn't going to help much on a beach if the system can only sustain it for short bursts.
    Tideland Prius likes this.
  7. dipper
    dipper Senior Member
    1,242
    252
    This is where Toyota needsto wake up and put a real battery pack and a plug to fix this.
    fotomoto likes this.
  8. Tideland Prius
    16,683
    pluggggg innnnn...
    I wonder if Toyota can put two Prime batteries in series and hook it up to a RAV4.
  9. Prodigyplace
    12,720
    11,852
    Central Virginia
    If they put them in parallel they could use the same motors but double the range. If the batteries are in series that doubles the voltage meaning new motors and some ECUs need to be designed.
  10. Tideland Prius
    16,683
    Ahh oops. As you can tell, I'm not an EE haha.
    Prodigyplace likes this.
  11. dipper
    1,242
    252
    The other thing Toyota is stupid is that they were already helping Subaru to put the Prius Prime EV system for Subaru's PHEV.... they could just have their team double up on the Rav.
    I had high hopes for Toyota, guess I will have to buy a Subaru then.
  12. Prodigyplace
    12,720
    11,852
    Central Virginia
    Suburu may not license the whole HSD system. Ford only licensed parts of HSD for their hybrid, for instance.
  13. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    What evidence do you have that they are not?
    Toyota tends to remain very quiet about releases until they are ready to actually roll out.
  14. dipper
    1,242
    252
    According to the press, Subaru is taking most of Prius Prime except the ICE.
  15. dipper
    1,242
    252
    Toyota is known to trademark everything they are working on. And nothing there.
    I can bet they we will not see a 2019 Phev Rav.... want to bet on it? One year suspension on PriusChat for the loser?
  16. pilotgrrl
    891
    1,797
    Chicagoan in TX
    Why get your knickers in a twist? Toyota owns 16.48% of Subaru.
  17. john1701a
    12,840
    5,312
    58
    "Prime" is already trademarked.
  18. Tideland Prius
    16,683
    We're assuming they're not.
    This.
    Well, we're assuming they're using Prime. They could follow Mitsubishi and just name it the RAV4 PHEV.
  19. Prodigyplace
    12,720
    11,852
    Central Virginia
    Or RAV4 PHV like they use for the Prime in Europe.
  20. gamma742
    gamma742 Member
    178
    73
    Luxury
    "Limited Warranty"
    "The hybrid-related components, including the HV battery, battery control module, hybrid control module and inverter with converter, are covered for eight years/100,000 miles. In applicable states, hybrid-related component coverage is 15 years/150,000 miles with the exception of the hybrid battery, which is covered for 10 years/150,000 miles."
    _____________________________________________________________________________________________________________________________________
    I wasn't aware that some of the parts are 15 year???
    Is this new or has it always been this way in CARB States?
    All this time I thought it was 10 year/150 miles.
