2020 Hybrid Automotive Reconditioning unit
Discussion in 'Gen 2 Prius Main Forum' started by Brian Raul Matute, Jun 27, 2020.
  1. Prodigyplace
    12,567
    11,781
    Central Virginia
    Wow! Just 2 days and he is back on my list too.
  2. Prodigyplace
    12,567
    11,781
    Central Virginia
    I am sure you have seen the source code for the software to be so adamant.
  3. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,803
    2017 Prius c
    No but I know what good electronic design IS.
    So.....let's try this:
    Unless you have a plugin model AND the first thing you do after "reconditioning" is plug it into the wall..............
    What is the first significant event that happens with the HV battery ??
    It is NOT charging, because there is no charging source.
    It IS a fairly heavy dis-charge to start the gas engine.
    So if the battery fails upon it's first use, it is much more likely that it is the OUTFLOW of current that triggered the failure, not an inflow of charging current.
    Make sense ?
    ukiltmybrutha likes this.
  4. SFO
    SFO Senior Member
    5,302
    4,249
    Northern California
    No.
    Can we collectively give this thread a rest, the OP hasn't been online in over a month :whistle:
  5. sam spade 2
    7,035
    2,803
    2017 Prius c
    Yes. Happily.
