2020 maintenance schedule
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by priusmatty, Mar 8, 2021.
  1. priusmatty
    priusmatty Active Member
    304
    109
    Louisiana USA
    2020 Prius
    L Eco
    Could anyone post a link to it? Thanks!
  2. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    It's in your Service Handbook. Look at yours, it's for your car - they an be different for different cars only slightly older or newer, or different geographical areas.
    douglasjre likes this.
  3. Pulse07
    Pulse07 Active Member
    273
    140
    East Bay, California
    2020 Prius
    XLE AWD-e
    Every 5k or 6mo Tire Rotation
    Every 10k or 1 year Oil Change
    You can make an account on Toyota and download the service schedule and Owners Manuel if you got it used and Seller/dealer wasn't able to give you one.
    Tyfly likes this.
  4. royrose
    royrose Senior Member
    1,389
    953
    Foot of Pikes Peak
  5. Queueball
    Queueball Junior Member
    17
    Saline, MI
    2019 Prius
    I was so impressed by the graphic representation Mendel Leisk developed for gen 3 (and then followed up with gen 2) that I proudly plagiarized his outstanding work and did the same for gen 4. It took me a fair bit of searching to find the source document which for my model and US location is under “Warranty Information” in the Owner's section of Toyota.com
  6. douglasjre
    douglasjre Senior Member
    2,245
    751
    Null, NL
    Why waste time with a tire rotation? When the fronts are bald, throw them away, put the rears up front and put the new ones in the rear. Saves a lot of time
  7. MAX2
    MAX2 Senior Member
    1,436
    490
    101
    Third planet from the Sun
    The tires wear more on the front. Why move the rear to the front? Better to put a couple of new ones on the front.
  8. Mendel Leisk
    42,250
    Toyota Tech Info website has the pdf version of Toyota USA’s Warranty and Maintenance Booklet, maybe easier to navigate. On the home page click on “Manuals” tab, then fill in the vehicle info.
    I’ve done a 4th Gen spreadsheet I’m pretty sure, can look for it and post in a bit, for comparison.
    Attached:
    #8 Mendel Leisk, Sep 28, 2024
  9. Queueball
    17
    Saline, MI
    2019 Prius
    Mendel - Thank you. I'm going to have to improve my skills since I didn't find these when I searched.
    I interpreted the Toyota manual with the same result as did you with the exception of engine/inverter coolant footnote (1) on yours. I did not find that information, do you recall where it is? I also included "replace transaxle fluid" but without a specific period. I did so as a placeholder with the intention of adding that piece once discovered. Can you offer any guidance regarding that? Thanks in advance.
  10. Mendel Leisk
    42,250
    In the Toyota USA schedule it says to change both coolant circuits at 100k, and there’s diminutive “3” (footnote ref) after the statement. Flip forward two pages to the footnotes, and footnote 3 basically says to not do the inverter coolant change till 150k. And for both, subsequent changes every 50k.
    this odd contradiction has been thus for Gen 3 and 4 (not sure about 2). The inference you have to take is that the footnote governs, since it follows. But it is pretty silly, and they don’t bother to revise it. I’d have to check, but wouldn’t doubt it lives on for Gen 5.
    FWIW, my Canadian spec Gen 3 has a sticker on the inverter coolant reservoir that says to not change it till 150k miles (odd in itself, considering we’re “metric” now). But Toyota Canada says to change both at 100k miles (actually 160k kms), more or less the same thing).
    worth noting, all of these intervals are miles or years, whichever comes first, with 100k miles corresponding to 10 years, and so on. Well except for that decal on the inverter fluid, which talks about miles only, and which Toyota Canada tells me to ignore (in an email).
    also: my object with these spreadsheets is just to make an understandable representation of the schedule, not to embellish or add to it.
    dammit, I did type a few more paragraphs, on transaxle fluid and brake fluid intervals. But this is on my iPhone, and @danny’s half broken site serves up stale edits, and if you do multiple edits without a refresh you lose them. I’m tired, tomorrow lol.
    #10 Mendel Leisk, Sep 28, 2024
