2020 PP - Is it possible to disconnect the audio?
Discussion in 'Prime Audio, Electronics, and Infotainment' started by YMS_1975, Jan 22, 2021.
  1. YMS_1975
    YMS_1975 Junior Member
    Ontario, Canada
    2020 Prius Prime
    Hey guys,
    I have a 2020 Prius Prime & I was wondering if there's any way to disconnect the audio from my car.
    To clarify, I don't want any music to be able to be played in my car. I realize that this may mean I'll lose Bluetooth audio (for phone calls), but I'm willing to make that sacrifice.
    The only thing I'm not willing to sacrifice is the backup camera, so pulling out the radio completely is not an option.
    All I want is for no audio to come from my speakers. Can this be done? If so, what do you recommend be done to accomplish this?
  2. jerrymildred
    jerrymildred Senior Member
    11,517
    14,170
    Tampa, FL
    Unplug the speaker connection/s on the back of the head unit? It's really easy to access.
    YMS_1975 likes this.
  3. YMS_1975
    Ontario, Canada
    2020 Prius Prime
    TBPH, I have no idea how to do this. By the head unit, I'm assuming you mean the radio itself?
    Is there any link to a video out there that can show me how to do this?
  4. Salamander_King
    Salamander_King Senior Member
    11,024
    8,980
    New England
  5. jerrymildred
    11,517
    14,170
    Tampa, FL
    It is ridiculously easy. Just keep in mind that after you get out the single clip and you're ready to pull, pull a little here and a little there like in the video rather than all in one place. It comes free very gracefully that way. Then just unplug what you need to unplug.
  6. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    Any Toyota dealer OR audio shop should be able to do it for you at little to no cost.
    Please consider, however, that if someone who has no knowledge of this modification gets into your car and turns the volume up near MAX. that it might blow the outputs since there will be no load for them.
  7. Leadfoot J. McCoalroller
    8,291
    7,808
    Pennsylvania
    2018 Prius c
    Hang on, the speaker wires are in the same connector shells as some of the important lines.
    The speaker lines can be isolated and cut easily enough. With a little more work it could be made quickly reversible if you felt the need to protect resale value.
    I don't think you'll find a youtube that shows how to do only this but that one Jerry shared offers a lot of the important parts.
    jerrymildred likes this.
  8. jerrymildred
    11,517
    14,170
    Tampa, FL
    I did not know that they combined other wires with the speaker wires in the connectors. When I had mine apart, I wasn't looking into those kinds of things. Nice catch. And good point on still being able to disconnect/reconnect if you sort them out and put connectors on the ones you cut. (Last time I had a radio out with the intentions of replacing it was probably 30-35 years ago and I'm 99.9% sure the speaker wires had a dedicated connector.)
    I still don't understand why it would be necessary to make it totally impossible to prevent the sound system from making sound rather than just turning the volume down to zero.
    Genio951 likes this.
  9. pghyndman
    pghyndman Active Member
    498
    466
    CT shoreline
    Ummm...?
  10. bisco
    52,863
    don't turn it on?
    pghyndman likes this.
  11. Elektroingenieur
    2,515
    3,288
    Three Touring
    Not on this model. If the car has the six-speaker sound system, with the 7-inch display—the default for the base model in Canada, according to the 2020 sales brochure (PDF)—it should be straightforward to disconnect the speakers at the Radio and Display Receiver Assembly, also called the head unit.
    As the Electrical Wiring Diagram (more info) shows, connector I108 has only the wires to the speakers, so disconnecting it wouldn’t interfere with the rear view monitor system. This connector is the only one on the head unit with ten positions (in two rows of five) and eight wires. If it’s left disconnected, I’d suggest securing it to prevent rattling, perhaps by fastening the speaker wires to those of an adjacent connector using a nylon cable tie, fastened just tight enough to stay in place, but not so tightly that the wires might break.
    Removing the speakers is another option, but they’re mounted with rivets, which would have to be drilled out.
    The right front speakers are also used by the Safety Connect feature for emergency call audio. The wiring for these speakers goes from the head unit (I108) to the telematics transceiver (DCM), and then on to the speakers, and I’d imagine that Toyota’s designers would have made sure that leaving the speaker circuit unterminated at the head unit wouldn’t cause a problem.
    I wondered about that, too. If it’s a matter of conscience, I’d respect that, but if it’s just a rebellious teenager, I’d suggest that anyone who can’t be trusted with the volume control also shouldn’t be trusted with the steering wheel, brake pedal, or accelerator.
  12. sam spade 2
    7,035
    2,804
    2017 Prius c
    Not even close.
    Audio also comes from all kinds of system alerts.
    I assume those come through the head unit.......but maybe not.
    I'm taking bets on whether this is:
    Just some hairbrained idea.
    OR
    There is an actual legitimate reason for wanting total quiet.
    I sure hope we find out.
  13. pghyndman
    498
    466
    CT shoreline
    Fair enough if talking about ALL audio, but OP's original statement was:
    "To clarify, I don't want any music to be able to be played in my car. I realize that this may mean I'll lose Bluetooth audio (for phone calls), but I'm willing to make that sacrifice."
  14. Elektroingenieur
    2,515
    3,288
    Three Touring
    The aural warnings come from other parts: the combination meter, skid control buzzer, blind spot monitor buzzer, and no. 1 and no. 2 clearance warning buzzers. (The onomatopoeia is lost in translation.)
  15. ChapmanF
    19,037
    I thought buzzing was kind of inherent in bee-ness, whether they are angry or not.
  16. sam spade 2
    7,035
    2,804
    2017 Prius c
    Yes I KNOW that those sounds originate in other places but they come through the head unit on their way to the speakers.........right ??
  17. Elektroingenieur
    2,515
    3,288
    Three Touring
    The warning sounds (that is, the vibrations in the air) are generated directly by the other parts I mentioned. Neither the head unit nor any of the speakers that are usually connected to it is involved.
  18. bisco
    52,863
    ahh sam, sam, sam...
  19. jerrymildred
    11,517
    14,170
    Tampa, FL
    Piezoelectric, aren't they?
  20. ChapmanF
    19,037
    I was wrong
    So were you
    What will you do?
