2020 Prime Charging Door Jams
Discussion in 'Prime Main Forum (2017-2022)' started by epete, Nov 1, 2019.
  1. epete
    epete Member
    76
    27
    New Jersey
    I have had my 2020 Prime for 3 months now. I have now experienced the Charger Port Door jamming in its closed position where I am unable to press to release the latch and open the door two times so far. Has anyone else experienced this? Is this a design flaw that I will periodically have to deal with or is this a problem that can be fixed?
  2. Tickwood
    Tickwood Active Member
    334
    101
    San Diego
    2020 Prius Prime
    Is the car locked???
    jerrymildred likes this.
  3. jerrymildred
    jerrymildred Senior Member
    11,517
    14,164
    Tampa, FL
    If the car's locked, it won't open. If it's not locked, it should still be under warranty. This is not normal.
  4. schja01
    schja01 Senior Member
    1,867
    1,235
    Chicagoland
    2024 Prius
    Limited AWD-e
    I’ve had it jam when I forgot to move the protective cap from the stow position back to the charging port and then tried to close the door. It jams semi closed and is difficult to get unjammed.
  5. vvillovv
    vvillovv Senior Member
    4,336
    1,518
    NY
    Which model 2020 Prime do you have?
    I have the 17 Prime Plus without the chargeport door lock.
    20191101_chargeportdoor1.jpg 20191101_chargeportdoor2.jpg 20191101_chargeportdoor3.jpg
    maybe someone with the locking door can post a shot or two if your model has the lock
    #5 vvillovv, Nov 1, 2019
  6. jerrymildred
    11,517
    14,164
    Tampa, FL
  7. vvillovv
    4,336
    1,518
    NY
    How long did it stay jammed the two times? How did you finally get it open after it jammed?
    What difference(s), if any did you notice the two times this happened?
  8. epete
    epete Member
    76
    27
    New Jersey
    Thanks for all of the helpful info. I will have to see if it happens again when the doors are unlocked. I was unaware of that. To get it to open I had to constantly try and open and finally it opened (both times).
    vvillovv likes this.
  9. jerrymildred
    11,517
    14,164
    Tampa, FL
    Well, if the car doors are locked, the charge port door won't open no matter how many times you try. If it opens after multiple attempts, then something must be out of adjustment. Look around the edges of the door when it's closed to see if it's rubbing on the car body. Or there could be something wrong with the "latch button." It's just a push to latch, push to pop out thing like some stereo cabinet doors. You can leave the door open and push that button to see how it works. All it does is extend and push out the door enough for you to get your fingers behind it.
  10. Tideland Prius
    16,665
    Unless you have the SKS fob with you. It's possible he might be standing just outside of range and reaching into open the flap which can result in a flap opened ajar. You'll have to close it and then push it to open again.
    vvillovv and jerrymildred like this.
  11. jerrymildred
    11,517
    14,164
    Tampa, FL
    True dat! I just went outside and made sure on my own car. (y)
  12. VTBIGDOG
    VTBIGDOG Active Member
    211
    146
    If the car doors are locked and you have the key in your pocket, pressing the charge door will cause the car to unlock.
  13. ctscoob
    ctscoob Junior Member
    56
    36
    CT
    2020 Prius Prime
    This is probably a dumb suggestion, but are you pressing in the center of the charging port door? I only ask because I struggled the first few days opening mine and it suddenly hit me you have to press it in the center. If you try pressing it on the edge it won’t open very easily.
  14. jerrymildred
    11,517
    14,164
    Tampa, FL
    That's really interesting. There must be differences in how various ones fit and work. Mine does best if I press right where the "push the door open" button is.
    Tideland Prius and vvillovv like this.
  15. r.p.
    r.p. Junior Member
    @schja01: What did you do to unjam it? We just had the same thing happen on our 2022 Prime. I've got a slender steel strip (from a street cleaning bristle) that I could use if I knew where I needed to press...
  16. jerrymildred
    11,517
    14,164
    Tampa, FL
    @r.p., I'm not sure what he did, but what jams it is that the locking pin has side pressure on it from the charge cap pushing the door outward. What I would try is pushing in on the door to relieve that pressure while locking and unlocking the car with the fob. If you get the pressure off the pin it should be able to retract.
  17. Old Bear
    Old Bear Senior Member
    712
    1,050
    Boston, Massachusetts USA
    I can only speak to the 2017 Prime, but the owners' manual provides the following information:
    Check your owners' manual to see if this procedure is still applicable to your model year.
    In any event, this should not happen unless you try to force the door shut when the protective connector cover is not properly in place or when some other debris is caught in the door. Otherwise, if this is a recurring problem, you should seek help from your Toyota dealer.
  18. schja01
    1,867
    1,235
    Chicagoland
    2024 Prius
    Limited AWD-e
    A slender screwdriver wrapped in a layer of electrical tape to not damage the paint.
