2020 Prime. ICE started itself while plugged in (in the garage!).
Discussion in 'Prime Plug-in Charging' started by Reliable, Feb 7, 2020.
  1. Reliable
    Reliable New Member
    Vancouver WA USA
    2020 Prius Prime
    My apologies if this has been answered elsewhere.
    I got my 2020 Prius Prime LE in December of 2019. No surprises, absolute satisfaction until yesterday.
    My routine is to plug in the charger (110 wall outlet) each evening when I return home. I park in my attached garage.
    Yesterday I was home all day. In the early afternoon, it dawns on me that I hear a motor running. I went into the garage to investigate. The gas engine was running and the garage was full of exhaust smoke. All three blue charge indicator lamps on the dashboard were flashing in unison. I got everything turned off, opened the garage door to ventilate the smoke, and started hunting in the manual to figure out what happened.
    The best I can figure is that I put the key fob in my pocket and inadvertently pressed the remote A/C starter.
    But, in reading the manual, I think I understand that it is supposed to only use the battery to power the A/C for that function.
    The manual seems to only address use of the remote A/C starter in conjunction with a level 2 charger, but again I am using a 110 wall outlet. I think I understand that the dealer can disable the remote A/C function, which looks like a good idea. Can any of you help me understand what I might have done?
    I'm not finding an explanation for why the gas engine might start in my closed garage. I think I should invest in carbon monoxide alarms before I invest in a Level 2 charger.
    Thanks for your advice.
  2. Tideland Prius
    16,683
    Was there an aftermarket remote engine start installed instead (different from the remote A/C you mentioned).
    Alternatively, there’s a small chance you never turned the car off when you parked.
  3. Reliable
    Reliable New Member
    Vancouver WA USA
    2020 Prius Prime
    Thank you for the ideas.
    Nothing aftermarket on the car.
    I will experiment to see if the car will let me plug it in to charge without turning it off first.
  4. noonm
    noonm Senior Member
    575
    595
    2018 Prius Prime
    This is surprisingly easy to do and I've found myself doing several times since getting my Prime.
    I pretty much use the start button as my "park", so when I do actually use the park button, I often forget to actually turn the car off!
  5. Leadfoot J. McCoalroller
    8,292
    7,808
    Pennsylvania
    2018 Prius c
    ...and that's why there's a full ban on pushbutton-start cars inside my garage, thanks! They're welcome to sleep outside.
  6. bisco
    52,880
    this is a common issue, and nothing to be concerned about
  7. Reliable
    Reliable New Member
    Vancouver WA USA
    2020 Prius Prime
    Oh, that might be a useful habit to cultivate. I know that the car goes into park automatically when you turn off the power.
    It's possible I could have made that mistake, but I'm not certain--I am so interested in seeing my driving score that every time I stop the car I look for my number...also, it was parked for more than 24 hours before the engine turned on.
  8. Reliable
    Reliable New Member
    Vancouver WA USA
    2020 Prius Prime
    Can you elaborate on your response?
  9. Jon Bloom
    Jon Bloom Member
    77
    78
    Connecticut
    But doesn't the car beep at you if you close the door with the car on and the fob outside the car? Several times that's the only thing that has kept me from leaving the thing turned on in the garage.
  10. jerrymildred
    jerrymildred Senior Member
    11,517
    14,171
    Tampa, FL
    It does and it's saved me a time or two, but many of us, including me, have still managed to phase out and do it anyway. Leaving the car in READY and plugging it in is the only plausible explanation I've ever heard of or can dream up other than the possibility of a remote start. But I gather this is a new car, so that wouldn't be a surprise to the owner.
    And when you do that, the car will not charge the battery.
    #10 jerrymildred, Feb 8, 2020
  11. El Dobro
    El Dobro A Member
    7,106
    3,282
    If the car was left on, shouldn't the instrument panel be all brightly lit?
  12. bisco
    52,880
    if the car is plugged in, can the engine start?
  13. jerrymildred
    11,517
    14,171
    Tampa, FL
    I think so, if it was already in READY mode. The charger will not charge in Ready mode, so the traction battery will gradually lose charge. Eventually, it will get low enough that the engine will have to run to protect the battery.
    If the car was off and it was plugged in, I can't see how the engine could start unless the whole system got over ridden by some after market remote engine start device as @Tideland Prius mentioned.
  14. bisco
    52,880
    a lot of us forget to shut down our cars. fortunately, there is very little toxicity to primes exhaust.
    your description of 'the garage is full of exhaust smoke' is disconcerting though. you may want to have the engine and pollution control system analyzed at the dealership.
    Reliable likes this.
  15. jerrymildred
    11,517
    14,171
    Tampa, FL
    I do that stuff, too. :D
    It could easily take that long depending on the state of charge.
  16. Reliable
    Reliable New Member
    Vancouver WA USA
    2020 Prius Prime
    It's not that big of a garage...
  17. Reliable
    Reliable New Member
    Vancouver WA USA
    2020 Prius Prime
    I appreciate all this information, everybody.
    I've just had a chance to experiment and see if I could replicate this situation.
    I put it in park and left it turned on. When I got out of the car and closed the door, an alarm sounded (maybe it's a new feature--it is a good idea!). So, I don't think that's the solution here.
    For the next experiment, when I get the chance I will try to activate the remote A/C with the key fob and see if it turns on the ICE after awhile.
  18. Salamander_King
    Salamander_King Senior Member
    11,024
    8,980
    New England
    ICE should not start with remote A/C. The strange thing is that you had a charge indicator lit while ICE is on. This should never happen.
    jerrymildred likes this.
  19. Tideland Prius
    16,683
    They weren’t lit. They were all blinking in unison. That implies some sort of error.
    #19 Tideland Prius, Feb 12, 2020
  20. Salamander_King
    11,024
    8,980
    New England
    OK, so it is not the indication of "charging in progress" nor "charging complete". Humm, I have never seen mine does that. What does that indicate?
