2020 Prime XLE: Auto-Dimming Mirror Installation?
Discussion in 'Prime Main Forum (2017-Current)' started by WafflesMcDuff, Dec 26, 2019.
  1. WafflesMcDuff
    WafflesMcDuff Junior Member
    Auburn Hills, MI
    2020 Prius Prime
    I'm picking up a 2020 Prime XLE at the end of this week. I read on other threads that Toyota just uses Gentex ADVGEN40A4 mirrors as "OEM" so I'm considering just doing this one myself. I've seen videos of other Vehicles (such as Nissans) having the connector for the autodimming mirror just sitting up in the ceiling of the car already, behind the map light pop-out, making it fairly plug and play. Is this the case with the 2020 Prime XLE as well? Or am I going to need a wire-tap or something similarly invasive?
  2. smyles
    smyles Active Member
    293
    192
    US
    2019 Prius Prime
    You'll need a Prius specific mirror, as it has a longer 'stem' to clear the front camera cover.
    Can't speak for 2020, but '18 and '19 aren't pre-wired and you have to run wires and tap in.
  3. WafflesMcDuff
    Auburn Hills, MI
    2020 Prius Prime
    Do you know if the mirror used on the 2011 Prius-III would work on a 2020 Prius Prime?
  4. smyles
    293
    192
    US
    2019 Prius Prime
    no clue, but highly doubt. Did they have lane assist in 2011?
  5. WafflesMcDuff
    Auburn Hills, MI
    2020 Prius Prime
    No. Does the lane assist use cameras mounted near the rear view mirror?
  6. smyles
    293
    192
    US
    2019 Prius Prime
  7. GregersonIT
    GregersonIT New Member
    Livermore
    2020 Prius Prime
    No reason you can't easily do it. Seriously, it's a two wire hookup. I wouldn't even let a dealer touch it. Refurbished mirrors can be had for 60 bucks easily.
Loading...
