2020 Prime
Discussion in 'Prime Main Forum (2017-2022)' started by pruiskip, Nov 17, 2019.
  1. pruiskip
    pruiskip Junior Member
    Lecanto, FL USA
    2020 Prius Prime
    I have bought a new 2020 Toyota Prius Prime Hybrid Plug-In. It now has 1,780 miles with 199.5 MPG. (combined gasoline and electric) I have had it over 260 MPG. I get around 33 miles off the battery, then over 70 MPG with the gasoline. I start slow when the red light turns to green. I use the hybrid monitor to help drive miserly. My first new 2010 Prius got 53 MPG. My second 2016 Prius got 64.7 MPG over to 90,910 miles.
    With the use of the charging cable that came with this car, it takes around five hours to charge the empty battery. I am looking into getting a 240 volt, 40 amp charging station to reduce the charging time. Any advice about this idea? I'd like to hear from you! THANKS
    kepani, Matt1984 and bisco like this.
  2. jerrymildred
    jerrymildred Senior Member
    11,517
    14,164
    Tampa, FL
    Welcome! And well done.
    The cheapest way to charge at 240V (assuming you already have an outlet in place) would be to make an adapter for your EVSE cable. Lots of people are doing that and love it. It will cut your charge time in half. If you don't want to make your own, @Rob43 has quality adapters for sale.
    Next cheapest is to get an L2 EVSE cable from Ebay or Amazon for a couple hundred dollars. These will charge at 16 amps and get the car charged a little quicker.
    Or you can go whole hog and get something like a Clipper Creek wall mounted EVSE that will email you when the car is done charging and has other nice features but costs quite a bit more.
    If you don't have a 240V outlet already, I recommend hiring an electrician to make sure it's done safely if you don't have the training yourself.
    By the way, Primes are hard to find here in FL. Did you order yours or was someone actually stocking them?
    Rob43 likes this.
  3. Salamander_King
    Salamander_King Senior Member
    11,024
    8,977
    New England
    Welcome to PC.
    As already mentioned, check out this thread Using the Primes 120v Charger at 240 Volts, Cost $20 !!! | PriusChat and contact @Rob43 for an adapter, unless you want to spend $$$ on fancy L2 EVSE.
    Rob43 and jerrymildred like this.
    52,761
    great numbers, all the best!(y)
  5. yiujai86
    yiujai86 Member
    35
    31
    Miami
    2020 Prius Prime
    I bought this and installed a nema 6-20 at my job. I only had to run a 12 guage wire because the length i needed was only 6 inches. Thee new cable is great. I have had it for 2 months now and probably plugged and unglugged it over 300 times because I drive a lot of short trips everyday for my work.
  6. Washingtonian
    Washingtonian Senior Member
    726
    621
    Not sure that starting slowly from a green light and "driving miserly" is such a good idea with these cars. Gets pretty expensive if you are rear ended. Personally, I like the extra torque the Prime has when starting out.
  7. Rob43
    Rob43 Senior Member
    1,373
    1,050
    VA, BMW Race Car, BMW R1200R, BMW 330Ci, Ford F350
    2013 Prius v wagon
    Congrats on your new Prime !
    Your included Toyota OE EVSE unit (charger) is probably one of the finest included EVSE's of any manufacturer, it's a really high quality piece. So I'd tell you to keep using it because it's great and it's FREE. Once you get yourself a 240v adapter, your charging time from 0% to 100% will take about 2:28 minutes. You won't be modifying anything, including your OE EVSE unit, so it can always work at 120v or 240v depending on your needs.
    On a side note, the Prime can't ever take more than a 16 amp EVSE unit. If you want a great working 240v adapter I custom build & test them before shipping for less than $50 dollars, just let me know.
    Using the Primes 120v Charger at 240 Volts, Cost $20 !!! | Page 8 | PriusChat
    Rob43
    #7 Rob43, Nov 18, 2019
    Matt1984 likes this.
  8. pruiskip
    Lecanto, FL USA
    2020 Prius Prime
    I agree with you completely, there is a modification for everything, depending on traffic.
    Yes, it is almost impossible to find a Prime in Florida. I have been trying to buy one for the better part of a year. Some dealers are marking them up $5,000. I got a great deal on mine (off the lot) at Phillips Toyota in Leesburg, FL.
    #8 pruiskip, Nov 19, 2019
    jerrymildred likes this.
  9. jerrymildred
    11,517
    14,164
    Tampa, FL
    Cool. I got mine used from Tampa Hybrids. If I was going to get a new one, I'd probably have gotten a one-way plane ticket to New Jersey or Maryland or something and driven it back.
  10. Matt1984
    Matt1984 Member
    36
    32
    San Diego
    2020 Prius Prime
    I am a new owner, too. I love tech and considered something like a JuiceBox Pro. I just can't justify the price. The Prius Prime let's you program charging times really easily right on the dashboard. Combine that with a 240 adapter and you have 90% of the functionality of the $550 JuiceBox Pro. I will be ordering a Rob43 adapter once I get my new 240 outlet installed. (y)
    illumiN8i, jerrymildred and Rob43 like this.
  11. D’rae
    D’rae New Member
    Claremont, CA
    Hey y’all! I have a 2020 Prius Prime XLE. A month after getting it a lil freeway rock made a huge horizontal crack in my windshield. Safelight ordered a new windshield and they’re telling me the 2020’s don’t require recalibration but I don’t completely believe that is correct —does anyone know if a windshield replacement will require recalibration for the 2020 prime? Thanks
  12. Salamander_King
    11,024
    8,977
    New England
    I've never heard or read anywhere that 2020 forward facing camera is any different from previous model years. Yeah, I don't believe what Safelight is telling you. Did they order an OEM glass? I have read somewhere that aftermarket is now available but may not be acoustic windshield as OEM glass is. On the other hand, OEM glass is apparently very thin and prone to crack. I wonder if the aftermarket one is thicker and better in terms of durability? I had to have the windshield replaced on my 2017 PRIME and had a Toyota dealer re-calibrate the camera. The cost was ~$150.
    D’rae likes this.
  13. eveyo
    eveyo Junior Member
    85
    2019 Prius Prime
    D'Rae
    I had same problem. Insurance wanted me to go through safelite as they seem to have a contract with them. Safelite mobile came out and couldn't fix chip, said windshield needs to be replaced.
    Get quote from dealer. Call insurance and submit this to ask for coverage. Let them know you want oem parts and that it has to be oem for safety features to work and that you are concerned about your safety if not done properly. Toyota has to be the ones to calibrate lane departure. Honestly with the safety system tied to this
    I would go through the dealer for this.
  14. Marine Ray
    Marine Ray Senior Member
    1,139
    949
    Sparks, NV
    Why do you need to reduce the charging time? I considered spending bucks on a level 2 set up but are doing just fine with the overnight level 1 charge. No different than charging your phone while you sleep.
    kepani likes this.
  15. kepani
    kepani Member
    63
    67
    2020 Prius Prime
    Congratulations! I'm a new owner too as of November. This is my first Prius...and I'm just blown away at how efficient this car is. Enjoy and welcome!
  16. jerrymildred
    11,517
    14,164
    Tampa, FL
    Depends on his driving demands. There are usually 2-3 times a week when L1 is not fast enough for me.
    Marine Ray likes this.
  17. D’rae
    D’rae New Member
    Claremont, CA
    Thanks for your reply...
    $150 just to recalibrate? How much was the windshield replacement ?
    Thanks for the tips. Did you end up going through the dealer and having it covered by your insurance? How much was your dealer quote?
    #17 D’rae, Dec 4, 2019
  18. Salamander_King
    11,024
    8,977
    New England
    Everything was paid by my insurance. The dealer subcontracted the windshield replacement to the local auto glass shop. They submitted the claim directly to my insurance, so I don't know the final bill, but the installer I talked to told me the OEM glass they had to special order was ~$600 IIRC. ~$150 recalibration fee was paid to Toyota dealer out of my pocket, but later I was reimbursed from my insurance company.
