2020 Prius Prime delivered with empty EV Battery
Discussion in 'Prime Main Forum (2017-2022)' started by alvinator, May 27, 2020.
  1. alvinator
    alvinator Junior Member
    SW Florida
    2020 Prius Prime
    We picked up our new 2020 Prime today. It had a full tank of gas and a fully empty EV battery. Yesterday, when I test drove it the EV battery was also discharged.
    I was told that they don't sell many Primes and the salesperson was responsible. I call it complete stupidity.
    Any one have any thoughts?
  2. Mendel Leisk
    42,369
    Sure: charge it up and move on.
    Maybe just for giggles: check your tire pressures too (with the car having sat a few hours). If they're all at max sidewall, you know the dealership was just "mailing in" the PDI, and maybe you want to dig a little deeper. For example, I believe there's a couple of oblong hole plugs that are supposed to be installed on openings towards the rear, on the underbody, just inboard of the rear scissor jack bearing points. They've been reporting missing, or just tossed in the glove box.
    #2 Mendel Leisk, May 27, 2020
    Michael Wood and alvinator like this.
  3. Salamander_King
    Salamander_King Senior Member
    11,024
    8,980
    New England
    That's nothing new. Dealer almost never charge up the PRIME. It is not good for the battery to be fully charged and not driven right away. I would say, 9 out of 10 PRIME sold in the US was not charged. This includes the NE region where tons of PRIMEs are sold. My two PRIME were not charged when I picked up.
    alvinator likes this.
  4. alvinator
    SW Florida
    2020 Prius Prime
    Thank you for your valuable information. I consider the case closed. Primes are hard to find in Florida.
    Salamander_King likes this.
  5. Bob Comer
    Bob Comer Active Member
    708
    460
    South Carolina low country
    My car wasn't charged either, in fact, the charger was in the back of the car all in plastic. I plugged it in that night. :)
  6. Tideland Prius
    16,683
    Fortunately my dealer is on top of things. They have two chargers in the dealership (And it's a temporary space too, while the original location is under full renovations) - One for test drives and the other in a customer spot (but seems like the dealer also uses it to charge their Primes). Both my test drive and my personal vehicles were fully charged.
    Unfortunately, plug-ins are still rare (and the Prime is Toyota's only plug-in vehicle... for now) so salespeople aren't trained (or just slipped their minds I guess). Sucks? Sure but honestly because it's a small battery, it's just a small cost so I'd just forget about it.
    But I'd check the other stuff to make sure it's done like the tyre pressures.
    Raytheeagle and Mendel Leisk like this.
  7. huskers
    huskers Senior Member
    2,550
    2,489
    Nebraska
    I requested that mine be fully charged when I picked it up and it was.
    RunningFox and Raytheeagle like this.
  8. bisco
    52,891
    congrats!
    unlike gas, it's best to let them sit uncharged on the lot. rarely does any dealership remember to charge them before delivery. it's disappointing, but no biggie.
    all the best with it (y)
  9. Dennis_MA
    Dennis_MA Active Member
    185
    109
    Amherst, MA
    My dealer did not have a level 2 charger. So they plugged it in the morning I was picking it up and it was about 70% charged when I got it. I agree with others that most of the time they are delivered uncharged. My 2017 was not charged when I picked it up a few years ago.
  10. Rob43
    Rob43 Senior Member
    1,373
    1,050
    VA, BMW Race Car, BMW R1200R, BMW 330Ci, Ford F350
    2013 Prius v wagon
    Congrats on your new Prime !
    I see you've been a member for about 13 years with just a few posts, I'd recommend sticking around for awhile to learn about all the new fun things with your Prime.
    To add to the already mentioned things to look at, if you have a conveniently located 240 volt outlet near your Prime, you can use your 120v EVSE unit (charger) to charge your Prime much faster. Your cost is less $50 dollars and your charge up time will drop down to 2:28 minutes.
    Rob43
  11. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    The drive home from taking delivery can at least include some EV, even when leaving the dealer with nothing.
    It's an opportunity to use Charge-Mode, which supplies electricity at double the level-2 rate while in motion. See...
    GSK likes this.
  12. bisco
    52,891
    not the point:rolleyes:
  13. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,530
    Bay Area, California
    2019 Prius Prime
    Same here:).
    There are plenty of options out here, so they are more compliant to consumer requests;).
    They had a 120v outlet on the outside of the showroom which was perfect for our Prime for delivery(y).
  14. RunningFox
    RunningFox New Member
    MS
    2018 Prius Prime
    My central MS dealer had a single Prime to test drive and it was never charged. I requested that it be charged before delivery to myself and they took care of it.
    On a side note, the OEM MFG plant I work at changed battery voltage specs on our hybrid so they would come from our supplier into the plant with less overall charge. We don't make sure its fully charged as dealers do this during PDI (pre delivery inspection) as they do with the full gas tanks. When we ship cars, they have maybe 10-15 miles worth of gas and since everything costs money, i'm sure that has something to do with it and very likely any federal regulations about batteries and charge states ya know?
  15. Michael Wood
    Michael Wood Active Member
    181
    118
    Boston, MA
    2020 Prius Prime
    My 2020 Prime wasn't charged either. My drive home from the dealership was 55 miles and it didn't charge up much on the way home either. But I was not using charge mode - just regular hybrid. Still, coming from a 2015 Prius this seemed a little unusual to me. The next day I gave it a full charge, and took my first EV drive. Very impressive!
    I think my biggest challenge now is going to be keeping my battery in a depleted state when I'm not driving much. I hear that's better for battery longevity. I'll need to find a balance between EV and Hybrid modes. I could be tempted to almost never use my ICE. I'll have to force myself LOL
  16. john1701a
    12,840
    5,312
    58
    Reminds me of the misconceptions we had to address back when Prius was new... decades ago. btw, I just celebrated my 20th anniversary of Prius ownership. You'll find that assumptions come from people not posting enough information. That ends up feeding a common belief. After awhile, that becomes a misconception... which can take years to finally squash. Fortunately, we have many years of data to combat with already.
    In this case, longevity belief comes from people not understanding that there is no "full" for Prius Prime. There is for other devices that us lithium batteries, like your phone or an electric lawn-mower. But for the Toyota system, maximum is really only 84% of total available capacity. There's a buffer built into the software which prevents you from ever reaching full. So when the display shows 100%, it really isn't.
    That limits the "not driving much" concerns down to if you aren't driving at least once per week or you have the vehicle continuously parked in very hot conditions. Otherwise, there is no longevity benefit. My old 2012 Prius PHV is still working just fine without ever having done anything special for it. I recharged twice per day (overnight and at work) for over 5 years. The new owner (a friend of mine) just recharges whenever without any concern.
    Michael Wood likes this.
  17. bisco
    52,891
    so, no experience with low covid usage?
