2020 Prius Prime Long Term Storage
Discussion in 'Prime Technical Discussion' started by Zoos, May 21, 2021.
  1. Zoos
    Zoos New Member
    Palm Coast, FL
    2020 Prius Prime
    I will be storing my 2020 Prime Limited for about 5 to 6 months. I need advice on procedures to follow, especially concerning the 12 volt battery. I’ve seen some conflicting information as to whether the plug in charger also trickle charges the 12 volt battery. I saw nothing in the manual indicating that it does. Thanks for your help. Zoos
  2. Mendel Leisk
    42,343
    Safest bet with 12 volt would be fully charge it and then disconnect the neg cable. You could completely remove too. Or if you have a secure garage and a decent smart charger, you could leave a charger connected. Still, for that long, I’d side with disconnection.
    air up the tires to max sidewall pressure, even slightly higher. Alternatively you could raise the whole car and settle onto safety stands. Just high enough to take almost all the weight off.
    change the oil and filter.
    Fill the gas tank.
    Assuming sheltered garage, leave the car windows slightly cracked.
    tuck rags under the wiper arms to get them slightly off the glass.
    wash the car, and if you’re energetic wax it too. Pay attention to the corners, wheel wells and underbody.
    #2 Mendel Leisk, May 22, 2021
    Louis19 and jerrymildred like this.
  3. schja01
    schja01 Senior Member
    1,868
    1,236
    Chicagoland
    2024 Prius
    Limited AWD-e
    Traction battery not at 100% eg. 50->75%
  4. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    It only trickle charges the 12V while it's actively charging the traction battery. In fact ,the manual warns agains leaving the EVSE plugged into the car for long periods as it will add to the drain on the 12V.
    Run the traction battery down to below 50% (the manual says to use up the EV range). For sure don't leave it full. Li-Ion batteries don't self discharge, so it'll be fine at medium to low SC.
    Use a trickle charger on the 12v or disconnect the 12v negative.
    Louis19 likes this.
  5. Zoos
    Zoos New Member
    Palm Coast, FL
    2020 Prius Prime
    Thank you, Mendel.
    Thank you, Jerry.
    #5 Zoos, May 22, 2021
    jerrymildred and Mendel Leisk like this.
  6. P.Neophyte
    P.Neophyte Junior Member
    Fishers, Indiana
    2019 Prius Prime
    Jerry,
    Could you please explain why a long term plug in of the EVSE drains the 12V? Is it because the computer is constantly drawing current from the 12V battery to monitor the plugged in EVSE?
  7. jerrymildred
    11,517
    14,167
    Tampa, FL
    Yes, II believe so. The charger in the car and it's ECU is aware that the plug is connected and it monitoring the communication pins with the EVSE. That's not a LOT of energy, but it adds up.
  8. Mendel Leisk
    42,343
    Could you put the 12 volt on a smart charger while having the hybrid battery plugged in?
    jerrymildred likes this.
  9. jerrymildred
    11,517
    14,167
    Tampa, FL
    Sure! Actually, while the hybrid battery is charging, the 12v gets a trickle charge, but that stops when the hybrid battery is done charging.
    Louis19 likes this.
