2020 Prius Prime MPG
Discussion in 'Prime Fuel Economy & EV Range' started by Hoan, Apr 1, 2023.
  1. Hoan
    Hoan Junior Member
    Los Angeles
    2020 Prius Prime
    Hi everyone,
    I used Seafoam fuel injector cleaner. After I used it, my MPG went from 55 MPG to 45 MPG. I read this stuff can clog up your fuel system. Has anyone lse had this problem? I can remove my fuel injectors and have them professional cleaned from RC Injectors.
    If I do have my injectors serviced, how do I prime the fuel system?
  2. Gokhan
    Gokhan Senior Member
    6,654
    2,638
    Paramount CA
    Why would you try to clean fuel injectors on a three-year-old car? Top-tier gasoline already comes with detergent.
  3. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    No "priming" is necessary.
    BUT......don't panic just yet.
    There might just be a mistake in the calculations somewhere.
    Run all of that Snake Oil out of the tank, or most of it, and then see what happens after that.
    SeaFoam is NOT a good fuel system cleaner.......despite the marketing lies that they tell.
    A dose of Techron every 6 months or so is widely recognized as the best.......IF you insist on doing something that you don;t really need to do.
    If it ain't broke, don't "fix" it.
    52,638
    how many miles on your car?
