2020 Rear Defogger?
Discussion in 'Gen 4 Prius Main Forum' started by priusmatty, Feb 15, 2021.
  1. priusmatty
    priusmatty Active Member
    304
    109
    Louisiana USA
    2020 Prius
    L Eco
    Louisiana here. We got some very rare snow and ice. So I turned on the rear defogger/defroster, and after 20+ minutes, nothing happened. Nothing was melted at all. Is it broken?
  2. ChapmanF
    19,020
    Doesn't sound right. If you know anybody with a thermal imager, it can answer that question in seconds.
    Sometimes a piece of wayward cargo can scrape through some of the defogger pattern on the window, but that usually only leads to one or two lines that aren't heating (and can be fixed with some conductive paint).
    If none of it is heating at all, that sounds like maybe it isn't getting power at all. You could see if anything different happens if you use Techstream to turn it on.
    Mendel Leisk and priusmatty like this.
  3. robsnyder20
    robsnyder20 Active Member
    378
    302
    SW Florida USA
    In my last car, the person who did the tint cut thru a few of my lines on my defogger, just a thought. Can always check the fuse but you shouldn't see a light if its a fuse issue too
  4. priusmatty
    304
    109
    Louisiana USA
    2020 Prius
    L Eco
    I will check. Actually, it is a brand new car under warranty. I'll make the damn dealer check it lol
    AzWxGuy and robsnyder20 like this.
  5. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    Is the external mirror defogger working?
  6. priusmatty
    304
    109
    Louisiana USA
    2020 Prius
    L Eco
    Not sure, because there was no ice or snow on the side mirrors.
  7. alanclarkeau
    7,045
    7,593
    You should still be able to see if the mirrors are warm after being on for a while. Also - with the rear window, it turns off after, I think 10 or 15 minutes - so after 20 mins it would be cold again. (Not here - it's blazing sunshine.)
  8. The Professor
    The Professor Senior Member
    598
    809
    UK
    Excel
    Just throwing it out there, but it is an interior demister/defogger, not an external deicer/desnower. You remove the ice and snow on the outside manually, then let the car clear the steamed up windows on the inside.
    That's not to say snow and ice might not melt enough to slide off after a while, but it doesn't always.
    SM-T813 ?
  9. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    That's a good point. The one on my Prime won't even remove dew from the back window much less frost. It just kind of clears the surface right at the grid.
    alanclarkeau and priusmatty like this.
  10. ChapmanF
    19,020
    Huh. Mine of course doesn't make ice or snow cover disappear (on any reasonable time scale), but will definitely get stuff loose enough to shove right off the back window with my scraper, where otherwise I might be stuck back there chipping away at it.
    Tande likes this.
  11. priusmatty
    304
    109
    Louisiana USA
    2020 Prius
    L Eco
    took to dealer, they said it is working right.
  12. alanclarkeau
    7,045
    7,593
    did you check if the mirrors are getting warm?
  13. priusmatty
    304
    109
    Louisiana USA
    2020 Prius
    L Eco
    Yes, they made me feel the wires, and I could feel warmth.
  14. Tande
    Tande Active Member
    556
    339
    Mich.
    Same here.......
  15. Dael
    Dael Member
    137
    32
    Ohio
    2020 Prius Prime
    Do you have it working? My lower section doesn't seem to be functioning but need to dig deeper. I have an infrared thermometer... Soon!
