2020 Toyota Prius Prime Event Charge Schedule Not Working
Discussion in 'Prime Plug-in Charging' started by ryantranca, Jan 11, 2020.
  1. ryantranca
    ryantranca New Member
    Los Angeles
    2020 Prius Prime
    I just bought my car the latest model 2020 Prius Prime LE about a week. I'm having problem with Event Schedule Charging. I would like to set up my car to charge every night at 10:00pm, seems easy, however I can't get it to work, every morning, I check but my car was not charged the night before. Manually charge is working properly, but not for Event Schedule Charging. I brought my car to the dealer, after 6 hours trying from technician, they couldn't figure it out either. Now, the dealer is contacting Toyota to figure out what is wrong. Very confusing. Do any of you having the same issue?
    Thanks
  2. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,530
    Bay Area, California
    2019 Prius Prime
    Welcome to Prius chat(y).
    Some questions:
    • Is the car charging up at all?
    • Our 2019 Prime is set up to finish charging at a certain time. What time have you plugged in compared to the 10 PM time?
    Good luck and keep us posted(y).
  3. ryantranca
    Los Angeles
    2020 Prius Prime
    No, not charge at all (for schedule event charging), I plugged my car in 2 hours before 10pm.
    Not sure any limitation on LE model, any one having 2020 Prime LE ?
  4. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    I have had multiple problems on each Prius, the car employs different logic than we are used to. In my case I was hitting another button which actually caused the whole procedure to be null and void. Also, I was waiting
    for the “ CONGRATULATIONS “ feedback, which never comes. Hopefully your car is broke and they have to fix it. In my case it was simply procedure. Do not think the the Service Personnel that greet you are extremely
    swift, they may have never sat in a Prius before.
  5. GSK
    GSK Active Member
    169
    107
    Baltimore, MD
    Make sure that the calendar and clock are set properly. I couldn't get my charge schedule to work properly the first couple of days after I bought my car until I realized that the dealer or whoever had set the clock to 12 hours ahead.
    Froglegs and jerrymildred like this.
  6. jerrymildred
    jerrymildred Senior Member
    11,517
    14,171
    Tampa, FL
    I was going to say the same thing.
    And also, after you plug in with scheduled charging enabled, the green LED at the charge port should blink a few times and then go out until it starts charging. Once it goes out after you plug it in, if you open one of the doors, the dash should tell you when it's scheduled to start or stop charging depending on which type of schedule you're using. If it is charging when you open a door, the dash will tell you when the car expects to finish charging.
    Andyprius1 likes this.
  7. bluesman13
    bluesman13 Junior Member
    17
    Northern California
    2020 Prius Prime
    yes, that happened to me too - the dealer set the clock to AM instead of PM, and my scheduled charge was not occurring. It's confusing because the clock on the dash doesn't display AM or PM. I had to put mine in 24hr mode to set it properly. Once I did that, my scheduled charging worked. Thanks for the tip!
  8. jppacifico
    jppacifico New Member
    2020 Prius
    I was having the same issue with the timer. I just checked, and it was indeed the clock on PM vs AM. Thanks all!
  9. lochnersm
    lochnersm Junior Member
    33
    2020 Prius Prime
    I'm actually having a problem with a specific day. Schedule charging works for my regular weekday charging without a problem, so I know it's not a calendar/clock issue. I've even schedule charged for a sunday, but it does not want to schedule charge for Saturday. This is the 2nd time this is happening. It just tells me my next charge is for monday morning. It makes no sense. Anyone else have this issue?
  10. swavescatter
    swavescatter Junior Member
    Bump.
    Any way to set the calendar DAY? I’ve confirmed my clock is correct but I can’t seem to find the day/date.
    Charge now works, but a scheduled charge set for every night at 1:30AM someone doesn’t start?
  11. jerrymildred
    11,517
    14,171
    Tampa, FL
    Go to the meter customize settings screen on the MID. Quickest way there from the HSI display is to scroll left two places. Then scrollup or down till you get to the calendar setting page.
  12. swavescatter
    Wow, buried in there but I found it. Thanks!
    jerrymildred likes this.
  13. swavescatter
    …and just to confirm, my car is charged this morning!
  14. jerrymildred
    11,517
    14,171
    Tampa, FL
    You're welcome. Actually, since there are so many screens and sub-screens, depending on your starting point everything is pretty well buried in there. :D IIRC, it's six screens from left to right and then each of those has several screens up and down with some of those leading to other screens after hitting the ENTER button. If you invest some time exploring it, it'll eventually get more familiar. (y)
