2020 used key fob flashed/cleared? Possible???
Discussion in 'Prime Technical Discussion' started by FLYNBYU, Jun 3, 2024.
  1. FLYNBYU
    FLYNBYU Junior Member
    Webb City, MO
    2020 Prius Prime
    Does anyone know if a used oem 2020 key fob can be flashed/cleared and reprogrammed for a different car.
    TIA
  2. schja01
    schja01 Senior Member
    1,866
    1,235
    Chicagoland
    2024 Prius
    Limited AWD-e
    If the used FOB is the same model as the working one I'm 99% sure you can. The key point is you do need a FOB that currently works with the car.
  3. FLYNBYU
    Webb City, MO
    2020 Prius Prime
    I have a current working key fob, but was wanting a spare. The local locksmith told me that he doesn't know of a way to flash/clear the fob for the 2020 Prius.
    So, I'm looking for any technical support, ideas or anything that I can tell him that's needed to flash/clear the used OEM fob. The used fob is for the same model.
  4. schja01
    1,866
    1,235
    Chicagoland
    2024 Prius
    Limited AWD-e
    I may be speaking out of school or above my pay grade but I believe a dealer uses a tool called Techstream to do the cloning.
  5. FLYNBYU
    Webb City, MO
    2020 Prius Prime
    I will double check with them. Thank you
