2020 wheel covers
Discussion in 'Gen 4 Prius Accessories and Modifications' started by priusmatty, Feb 22, 2021.
  1. priusmatty
    priusmatty Active Member
    304
    109
    Louisiana USA
    2020 Prius
    L Eco
    2020 L ECO has alloy wheels with plastic covers. Do the plastic covers offer any aerodynamic advantage? Thank you.
  2. krmcg
    2,592
    2,393
    Whittier, CA
    Some people assume that they do because why else would Toyota add them. I tend to think otherwise and say that the added weight is counter-productive to MPGs. Plus the wheels look better without them.
  3. David9962000
    David9962000 Member
    141
    68
    2020 Prius
    You can get the center caps here:
    EconoModder likes this.
  4. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    If they improve mpg, then it's only by an infinitely negligible amount. I agree that the wheels look better without the covers.
    krmcg likes this.
  5. EconoModder
    EconoModder Member
    49
    26
    San Diego
    2021 Prius
    L Eco
    With other/older Prius models I would say yes, but these don't look to have been designed with aero particularly in mind. Typically these hubcaps weigh close to about 1 lb. That amount of weight reduction is negligible. I popped one off when I got my car recently to see how the wheel looked and I noticed the wheel didnt come with OEM center caps. I really don't feel like buying them for what they cost, so I just put the cap back on for now. I had considered a lightweight wheel, but it is so hard to find anything anymore in a 15" 5x100 pattern as almost nobody makes one. You have to go back and find used wheels from yesteryear back when 15's were a more common size. Anyway, I'm trying to stop myself from wanting to do that even, altho I would like more traction. I'm considering a 17x7 wheel with a 205/50/17 size tire, but prob won't end up doing it.
