2021 Annoying slow speed noise
Discussion in 'Prime Main Forum (2017-2022)' started by MarkOlin, May 18, 2021.
  1. MarkOlin
    MarkOlin Member
    78
    39
    Buffalo, NY
    2020 Prius Prime
    I recently moved from a 2020 to a 2021 Prime LE. With the new car i noticed an annoying noise at low speeds. The noise completely goes away when i hit 22 or 23 m.p.h.
    It's hard to describe the noise, kinda like a buzzing hum, maybe?
    I did not have this noise in the 2020.
    Any thoughts?
    52,847
    pedestrian warning system? does it sound like a spaceship kinda?
    they've been around since 2012, but gen 4 has volume control. maybe your old was on low, and new on high.
    Trollbait and schja01 like this.
  3. Ovation
    Ovation Active Member
    156
    130
    Quebec
    As of 2021 models, and I believe it is North America wide, EVs (and PHEVs operating in EV mode) are required to emit a sound to alert pedestrians (and must be louder in reverse)—WITHOUT the possibility of lowering the volume or turning it off (unlike previous model years).
  4. MarkOlin
    MarkOlin Member
    78
    39
    Buffalo, NY
    2020 Prius Prime
    you would think the engineers at Toyota would have come up with a less annoying sound. Kinda sounds like a bad wheel bearing grinding. Why is this noise heard only at low speeds?
  5. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    It's meant to warn pedestrians. (Hence the name, pedestrian warning system.) To put it crudely, at high speeds, the pedestrians would be dead before they heard it. ;)
  6. bisco
    52,847
    if you open your window in an enclosed space (parking garage, etc) you should easily be able to distinguish the sound from a wheel bearing and etc, at a few mph.
    Jotunn and Ovation like this.
  7. Salamander_King
    Salamander_King Senior Member
    11,024
    8,978
    New England
    As stated, that is a new vehicle proximity notification system (VPNS). You had it in the 2020 PP, but the sound level was much lower than the 2021 and was owner customizable which is no longer the case.
    #7 Salamander_King, May 19, 2021
  8. bisco
    52,847
    i would be curious to know the volume vs my 2012, which is also not adjustable, and if it is the same sound.
    but mine does not change with speed, and tops out at 15mph
  9. bisco
    52,847
    if you're in to civil disobedience, it can be disconnected :sneaky:
    lbligh likes this.
  10. jerrymildred
    11,517
    14,167
    Tampa, FL
    My 2017 Prime on the loudest setting is considerably quieter than my 2013 PiP was. But if the '21 Prime is like the '21 Rav4 hybrid, that sucker is seriously loud, especially in reverse.
    Not sure about that. I seem to remember seeing something about it throwing an error code if you just unplug it. You'd probably need some sort of terminal resistor to fool the system. But I have heard of people wrapping the speaker in bubble wrap to muffle it.
  11. MarkOlin
    MarkOlin Member
    78
    39
    Buffalo, NY
    2020 Prius Prime
    I'd like to re-program it to sound like a rumbling V8.....or to play Metallica
    pghyndman likes this.
  12. Pepperglove
    Pepperglove New Member
    Ca
    2002 Prius
  13. bisco
    52,847
    a lot of people have said that, but i have not seen it done.
    i think some ev's have options
  14. bluespruce
    bluespruce Member
    79
    72
    New England
    2020 Prius Prime
    This is what I want for my next car....The Jetsons car sound....its what the future sounds like haha
  15. Mendel Leisk
    42,343
    God I hope it’s not what the future looks like. :cry:
    Jotunn likes this.
  16. PiPLosAngeles
    PiPLosAngeles Senior Member
    1,551
    724
    Which is all based off of a study of only 186 crashes involving pedestrians and an EV vehicles that found a correlation between EV cars and pedestrian accidents but did not investigate whether there was a causal relationship. The correlation could easily have other explanations. For example, a UC Berkeley study conducted around the same time (2013) found "Prius drivers had a higher tendency to commit infractions than most."
    The Rich Drive Differently, a Study Suggests - The New York Times
    The study also did not differentiate between accidents involving a Prius running in EV mode vs. a Prius running under ICE power, which is a fairly important variable in a study purporting to be studying the dangers of EV locomotion. They did try to use "low speed maneuvers" as an indication, but as they wrote in the study:
    However, the sample sizes associated with these individual maneuvers are relatively small, which may make it difficult to achieve statistical significance due to low power. In fact, among the low-speed maneuvers, only the maneuver of “making a turn” indicated a statistically significant difference at conventional levels.
    EDIT - And I forgot to add: The study used the posted speed limit as an indicator of how fast the vehicles were traveling at the time of the accident. However, if the other study is accurate it would not be unreasonable to assume there's at least a real possibility that EV drivers are more likely to be violating the posted speed limit. Either way, the conclusions of the study hinge on some assumptions that weren't explored despite the fact that the very outcome of the study relies on their veracity.
    Upton Sinclair famously said, "It is difficult to get a man to understand something when his salary depends upon his not understanding it." In other words, I'm not surprised that faced with a choice of assumptions those whose jobs rely on the need for action chose the assumptions that justified them taking action.
    #16 PiPLosAngeles, May 22, 2021
    Washingtonian likes this.
  17. Ovation
    156
    130
    Quebec
    Yes. Yes it is.
    My neighbour who owns a 2010 Prius, was outside a few weeks ago when I was backing into my driveway and he came over to ask me if there was a problem with my Prius Prime. I assured him it was normal.
    jerrymildred likes this.
  18. jerrymildred
    11,517
    14,167
    Tampa, FL
    I have a devious idea. Next time you hear the neighbor start his old tech car, ask him what's making all that noise. :D
    Ovation and fuzzy1 like this.
  19. PiPLosAngeles
    1,551
    724
    I think it's the particular noise. I also think it sounds something like a failed sleeve bearing.
  20. Washingtonian
    Washingtonian Senior Member
    726
    621
    One of the things I enjoy about driving my PP in EV mode is the silence. If I upgrade to a Tesla, can I expect it to be much noisier when driving around town?
