2021 Heated Steering Wheel on 2016?
Discussion in 'Gen 4 Prius Accessories and Modifications' started by madmax21, Jan 29, 2025.
  1. madmax21
    madmax21 Junior Member
    16
    Minneapolis
    Hi all, just picked up a 2021 steering wheel that came with heating while purchasing a tss2.0 steering motor for my 2016 Prius and my comma driver assist device. Wasn't expecting it to be included but now that it is - is it simply plug and play or did the car have to be specced with it? Don't want to pull apart my own steering wheel if it won't work lol.
    Let me know, thanks!
  2. Robert21PrimeLTD
    105
    50
    South of Nashville
    My 2021 Limited came with a heating steering wheel. On my vehicle, when I push the button to turn the heat on, an icon appears on the dash. My assumption is that that the button (switch) turns on the heat so that there must be wires connected to the wheel assembly that provides power. Not sure what the voltage is. You could test the wheel before installing it by connecting it to a battery to see if it heats up but be sure to find out what voltage is required so that you don’t destroy anything. The heat should be in the 10 and 2 positions on the wheel.
    Hope that this little information helps.
  3. madmax21
    16
    Minneapolis
    Little update - I tested the wheel before installing and compared the clock springs. Looks like I may be missing a plug on the harness for the clockspring. Will ask here and then in a new thread - does anyone have a pinout for the electrical connections on a 2021 prius steering wheel/clockspring? Everything else connected and worked fine, so my potential thought is if I manually run a 12v and neutral to the two pins on the 2021 clockspring, I can make a diy rocker switch to feed power manually to the heated steering wheel.
  4. Mypriuschatname
    Mypriuschatname New Member
    Toronto
    2018 Prius
    Four Touring
    Did this end up working out for you? I have recently purchased a 2018 and the steering wheel has some damage to it. Found one from a 2021 but curious if you ran into any issue with the swap from year to year. Thanks.
