2021 Prius - Disable Virtual Engine Sound - AKA Spaceship hum
Discussion in 'Gen 4 Prius Accessories and Modifications' started by Armitage Shanks, Dec 22, 2020.
  1. MIkeDr
    MIkeDr Active Member
    252
    138
    Seattle, WA
    2020 Prius
    XLE AWD-e
    A one month Carista subscription to turn off the incessant rear beep noise was money well spent. I recently rented a Prius Prime and forgot that the rear beep noise repeats since having turned it off in our non-Prime Prius.
  2. Colorado Boo
    Colorado Boo Active Member
    307
    202
    Monument, Colorado USA
    2021 Prius
    LE AWD-e
    Well I still can't find my speaker that's supposed to be near the driver's headlight..will have to get my flashlight and look. (Can you see it from above or do I have to go underneath?)
    The backup beep reminds me of a funny story from years ago.
    A mother and young son were waiting in the checkout line at the grocery store and were behind a rather large lady. Suddenly, the ladies beeper went off and the young son loudly yelled, "Watch out, everybody...she's backing up!"
    Noghri, jerrymildred and Mendel Leisk like this.
  3. jerrymildred
    jerrymildred Senior Member
    11,517
    14,151
    Tampa, FL
    Try this thread.
    Vehicle Proximity Notification System | PriusChat
  4. MarkOlin
    MarkOlin Member
    78
    39
    Buffalo, NY
    2020 Prius Prime
    2020 = 3,
    2021 = 11
    Mambo Dave, Noghri and MIkeDr like this.
  5. MarkOlin
    MarkOlin Member
    78
    39
    Buffalo, NY
    2020 Prius Prime
    where is the speaker located on 2021 model?
  6. jerrymildred
    11,517
    14,151
    Tampa, FL
    I would be extremely surprised if they moved it.
  7. Colorado Boo
    307
    202
    2021 Prius
    LE AWD-e
    I finally got time to tinker around with my UFO speaker. I tried getting to it from below (took off a cover)....no bueno. So I removed the 8 clips that hold on plastic cover right where a radiator would be, on top, and it's right near the top, on the right but before you get to the headlight.
    A 12mm wrench will disconnect the speaker and then you unclip the wires to get it out. I double-wrapped a sponge on the front and duct-taped it on. I'd rather just remove it but I guess we get a check engine light and we never want that.
    You can, still, hear it in reverse but it's about half as loud and in drive, when driving slow, you can barely hear it.
    I'm going to redo it with some small squares of wood (on front and back as it seems to be coming into the cabin even louder) and also use black tape (maybe electricians tape) because if you look in the front grill you can see it, but it is back a ways so not too obvious.
    ET go home!!!
    (I have pictures if anyone is interested.)
  8. jimmyjam
    jimmyjam WE KNOW ITS A PRIUS BECAUSE OF THE WAY THAT IT IS.
    181
    Iowa....a place to snow
    i was a mechanic for years. I accessed mine, disconnect spaceship speaker wire connection while power is off. Its a two prong connector. simply place an isolated jumper wire to the terminal you unplugged. computer doesn't recognize that any this has been bypassed. Yes I live on the edge. Rule breaker.... Love the quiet prius again.
  9. Bruce22
    Bruce22 Junior Member
    Coastal CA
    To a dumb dumb layman, what’s a isolated jumper wire.
  10. Colorado Boo
    307
    202
    2021 Prius
    LE AWD-e
    Mine, still, wasn't quiet enough so I got some small roll of foam insulation at Home Depot (that's used for insulating pipes) and wrapped the entire thing like King Tutt....can barely hear it now.
    I, also, got an OBDII with wifi and got my Dr. Prius working...and the setting to turn off the backup beep works. (Instead of the constant beeping, it only does 2 or 3.) Sweet....I tested my 2021 battery and it's saying 115%...so that's good....will test the 2017 this weekend.
    priustexasbob likes this.
  11. jimmyjam
    181
    Just a piece of insulated wire. Like from a Romex role. Or just 12-14 gauge single piece of braided wire. Just plug one end of wire into one side terminal and the other end into the other side of the two prong thing you unplugged from the buzzer.
    Skavis likes this.
  12. kc5dlo
    kc5dlo Active Member
    266
    163
    DFW TX
    2021 Prius
    I did not notice the noise either while on the test drive. The car was cold when we started the test drive thus the engine was running when I backed out of the parking space and did not notice the noise until on my way 175 miles to home.
    Mambo Dave likes this.
  13. DianneWhitmire
    DianneWhitmire High PRIUStess
    4,062
    1,123
    64
    Laguna Niguel, CA
    Good luck, I get at least 1 person a month thinking their car's broken - it's TOO LOUD! Talk about annoying. Worse for 21 now.
    Mambo Dave, bisco and krmcg like this.
  14. MScelery
    MScelery Junior Member
    Mississippi
    Got even worse for ‘22 than it was in ‘21!
    Has anyone tried the jumper wire solution @jimmyjam mentioned? If so, did it work??
  15. Colorado Boo
    307
    202
    2021 Prius
    LE AWD-e
    I did look around for that resister but couldn't find it anywhere and didn't dare messing up an ECU by using the wrong one so the insulation wrap is doing a great job...still puts out sounds but went from like a 10 to a 2. (And is easily removable if I ever get rid of the car.)
  16. MScelery
    Mississippi
    I used a paper clip and electric tape as a test. Worked out well for a test drive and threw no error codes, so I am now going to put actual wire in. 41¢ solution.
  17. Mambo Dave
    Mambo Dave Active Member
    641
    307
    2019 Prius
    L Eco
    Wow.
    At this point, it is so strange realizing that my next vehicle may not be a hybrid if they continually make them more annoying to own.
  18. jerrymildred
    11,517
    14,151
    Tampa, FL
    EVs are subject to the same regulation. But ICE cars, even though they are also usually almost silent in parking lots, are not required to have them.
  19. Joe Cowie
    Joe Cowie Junior Member
    39
    22
    Calgary, Alberta,Canada
    ----Canada----
    Does anyone have a video or step by step instructions on where to located the speaker and how to put in a jumper cable on a 2022 Prius prime to deactivate and turn off the VPNS noise maker?
  20. priustexasbob
    priustexasbob Member
    356
    86
    arrakis
    2015 Prius c
    I am wondering if you could spray the speaker with an "undercoating" type spray, that way it is still there and legal, "oh I did not realize it was a noise making speaker"
