2021 Prius mpg declining
Discussion in 'Gen 4 Prius Main Forum' started by William Grant, Jan 1, 2025.
  1. William Grant
    William Grant New Member
    South Carolina
    2021 Prius
    Ever since I hit rock in road and lost oil pan cover on undercarriage plastic my mpg have been slowly decreasing. I was around 54 before now reads at 52.8 with no indication will go back up to the 56 when first bought. Any suggestions on maintenance to improve mpg?
  2. jdenenberg
    jdenenberg EE Professor
    3,961
    1,957
    Trumbull, CT
    2020 Prius
    LE AWD-e
    There is always a noticeable MPG reduction in cold weather and it will go back up as things warm up. One thing to try is to check your tire air pressure. It goes down in cold weather and that will reduce MPG. I always run my tires at a somewhat elevated PSI (42 front, 40 rear) to get a bit better MPG.
    JeffD
    Brian1954 likes this.
  3. William Grant
    South Carolina
    2021 Prius
    Ok thanks will try that
