2021 prius Parking Aid Sensor
Discussion in 'Prime Main Forum (2017-2022)' started by baysidefish, Sep 18, 2022.
  1. baysidefish
    baysidefish Junior Member
    33
    usa
    2021 Prius
    LE AWD-e
    I have a 2021 Prius. When I backup my car this morning, the Parking Aid Sensor were on but it seems missing the front piece (see attached). After pumping the gas, when I pulled out off the station (forward), the front piece seems on again. Is this normal? thanks
    52,883
    no picture, can you try again?
  3. pghyndman
    pghyndman Active Member
    498
    466
    CT shoreline
    IIRC, my front detectors are blank while backing. Perhaps RCTA (rear cross traffic alert) and other functions are allocated priority over front sensors when backing up?
    To be honest, I ignore the grayed zoned patterns until a zone goes active.
  4. baysidefish
    33
    usa
    2021 Prius
    LE AWD-e
  5. baysidefish
    33
    usa
    2021 Prius
    LE AWD-e
  6. baysidefish
    33
    usa
    2021 Prius
    LE AWD-e
    The reason I asked was because I just replaced the front bumper and the grille shutter. I saw the front grayed zoned patterns was missing and was just wondering if that was normal. thanks
  7. Mendel Leisk
    42,367
    Lordy, just post in the thread.
  8. drash
    drash Senior Member
    2,600
    1,340
    Upstate NY
    XLE AWD-e
    Well if they didn’t glue them back into place then they may fall inside the bumper. Or maybe they gave you a bumper with no openings and just left them inside. Hopefully the sensors still have a wire on them. You’ll have to take off the bumper cover to look at the sensor. I had to do this as well because they kind of slipped inside because the double sticky tape they used failed. I ended up supergluing them in place and had no more issues.
    iPad ? Pro
  9. baysidefish
    33
    usa
    2021 Prius
    LE AWD-e
