2021 prius using samsung phone
Discussion in 'Gen 4 Prius Main Forum' started by MikeV, Aug 20, 2023.
  1. MikeV
    MikeV Junior Member
    95
    philadelphia
    so car comes with android auto do i need to get a specific cable for my phone to plug into car to pull up apps on monitor or does this work via bluetooth. example google maps, youtube etc... I already connected my phone for calls etc
    if I nned a cable is it just the same as a usb charging cable or does it need to be different
    #1 MikeV, Aug 20, 2023
  2. BiomedO1
    BiomedO1 Senior Member
    4,600
    2,414
    Left Coast
    The standard USB-C charging & data cable should work fine; plugged into the USB connector - next to your cigarette lighter jack. Some USB cables are for charging ONLY - it must be able to carry data too... If your not sure, plug it into a computer to see if you can read data off your phone's drive.
    MikeV likes this.
