2022 Bolt EUV Initial impressions
Discussion in 'GM Hybrids and EVs' started by jerrymildred, Sep 10, 2022.
  1. bisco
    52,817
    no idea, but there are plenty of 23's on the lots around here, upwards of 40k for the plus.
    this says no, and yes:
    what-we-know-nissan-leaf-ev-replacement
  2. triggerhappy007
    triggerhappy007 Active Member
    498
    334
    Actually the battery is air cooled. Which doesn't help if it's warm or hot or freezing. They both DC charge at about the same speed but if you have to drive more than 400 miles a day, the Bolt will charge faster.
  3. Trollbait
    12,818
    It's passive air cooling; no fan, just convection while the car isn't moving. Which means ineffective cooling for DC charging. On long trips, that usually results in just the first DC session being done at the car's max rate. The rest are slower.
    Plug ins with a fan for cooling(early Hyundai's and Toyota's) haven't had the issues of the Leaf.
    jerrymildred likes this.
  4. GSK
    GSK Active Member
    169
    107
    Baltimore, MD
    It seems like the Bolt EUV has great visibility. I don't know what the specs are to compare to the Prius Prime, but at least to me it feels as though I have better viewing angles in the EUV. So far I'm really liking it! Unfortunately, so is my wife, who keeps wanting to drive it instead of her Leaf!
    jerrymildred, bisco and Louis19 like this.
  5. bisco
    52,817
    from the pictures, it does look pretty good. looking at the new prius in person yesterday, it reminded me of my miata.
    couldn't see a thing unless the top was down. more like a submarine. 40 years ago, i would have loved it.
    if mrs b starts driving my bolt too often, i'll be trading in her new hycam
  6. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    Did you sit in the driver's seat of the new Prius and try to see the instrument cluster? Every review I've seen (as far as I recall) hated that placement. It's as if the chief designer said, "We only have two places for the instruments. If you didn't like the old one, you for sure won't like the new one!" If not for that, they all love it. But that would sure be a deal breaker for me.
  7. jerrymildred
    11,517
    14,167
    Tampa, FL
    In other words, it cooled like a hot rock under a car. Not even so much as a fan on it to remove heat when DC fast charging.
  8. bisco
    52,817
    it wasn't for sale, so i couldn't sit in it. most of the buyers here say that if you adjust the seat height just right, the front to back just right, and the tilt of the seatback just right, you can see it fine.
    personally, i like to adjust the seat for my most comfortable driving position. if i can't see the speedo, that's a problem.
    i don't like online 'professional' reviews because their car people. give them fast and furious, and you'll get glowing reviews.
    my desires lie elsewhere. there isn't an online reviewer that i have seen that ever extolled the virtues of gen 2 as the best utility car ever made, which it was in my opinion.
  9. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    Makes me wonder who you were watching. I have seen a number of them that say it is just fine. As for my experience, visibility is no issue whatsoever. Makes me wonder if they were overlooking (pun intended) something.
  10. hill
    9,023
    It's pretty easy to explain people's different views of the Prius dash - cluster. Some people have long or short legs - putting the seat in different positions, while other people differ having long or short torsos ... which gives different dash views. It's not the first time this scenario has arisen and won't be the last.
    jerrymildred, bisco and Trollbait like this.
  11. FalconSeven
    FalconSeven Active Member
    152
    114
    It would have been better if Toyota had spent the money on a proper IP and a HUD. Instead, they half assed both and ended up with a mess. Which seemed to be the whole design philosophy behind the bx4z.
    Merkey and bisco like this.
  12. john1701a
    12,840
    5,312
    58
    Finding a means of delivering HUD without the expense of HUD is half-assed?
  13. Trollbait
    12,818
    I'm convinced the Prius and bZ4X dash display was designed to work with their yoke. The yoke just wasn't ready in time, and why it is an option on the new Lexus BEV. I expect it to be available with the Prius midcycle refresh.
    Louis19 likes this.
  14. bisco
    52,817
    try the toyota certified master mechanic 'car care nut'
  15. bisco
    52,817
    even bob wilson put a speedo display in his tesla line of sight. i don't get some of these mfg's decisions
  16. FalconSeven
    152
    114
    When it doesn't work, yes!
  17. FalconSeven
    152
    114
    I saw that... it's basically what VW has done with the id.4. Except, with the id.4, VW has gone to the expense of mounting the IP on the column so it moves with the wheel, ensuring it's always visible.
  18. john1701a
    12,840
    5,312
    58
    What do you think the purpose was?
    Remember, we've been through this before.
  19. FalconSeven
    152
    114
    To avoid spending money on implementing a proper IP and HUD.
  20. john1701a
    12,840
    5,312
    58
    Nope.
