2022 Consumer Reports Prius Prime mentions
Discussion in 'Prime Main Forum (2017-2022)' started by Marine Ray, Feb 17, 2022.
  1. Marine Ray
    Marine Ray Senior Member
    1,139
    949
    Sparks, NV
    Good points, thx. Further, many folks are unaware that the Prius prime's coefficent of drag is probably among the best in the world. I've seen .25 and .26
  2. Trollbait
    12,799
    Is it a comparison of a 5 year old car to a new one, or a comparison of first year issues for the 5 year old car to a 1 year old car? I never actually looked into CR's methodology for that.
    The important bit is that CR doesn't directly test a car's reliability. Unless they keep cars for extended periods like some other auto magazines. They use responses from surveys of their members for it.
    You can't claim the others were ignoring cabin heat efficiency. Heat pumps cost more than an air conditioner, even when not considering differences in market size. ICE cars don't need them, so how many automotive heat pump suppliers were there for EV makers to choose from. At a time when batteries cost much more than they do now. A heat pump does nothing for someone in the American south, why make them pay for it when the company does source one for their model? The biggest CARB state also has mild winters.
    All car companies bundle desirable features into packages for better profit. It wasn't that long ago when you could only get TSS in the higher trims of the Prius, and you still can't get a hybrid Rav4 without AWD in the US. Somebody who needs a heat pump for efficiency in an Ioniq 5 likely lives in an area where AWD for snow makes sense. AWD and winter is why the Prius with E-four uses a NiMH pack.
    But kudos to Toyota for making a heat pump standard in the second generation Prius PHEV, after costs have dropped some. If they had put out an EV with one sooner, those costs would have dropped faster. Too bad we had to wait through two PHEV models for a BEV that actually needs a heat pump for efficiency.
    Improved compared to who, the PiP? Nissan put in a battery heat system with the second model year of the Leaf. The Volt had a liquid thermal system for the pack from the beginning, which could heat it into efficient charging operation ranges, not just above the danger zone of freezing. The PP's and Leaf's system is a fix to a limitation of air cooling the pack.
    This is nifty.
    My Camry has a button to direct air output to my feet. I am pretty sure our cars with autoclimate directed more air to the foot wells when heating.
    Could have been better than the Prius if they hadn't let style get in the way of the Prime's front end.:)
    Salamander_King likes this.
  3. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    I didn't.
    That "they chose not to" means the opposite.
    Lower price meant trading efficiency.
  4. Trollbait
    12,799
  5. Tideland Prius
    16,665
    A vapour-injected heat pump which only recently the Koreans have added to their EVs (Ioniq 5 and EV6 and GV60).
    Toyota is still ahead with automatic S-Flow. Other companies require you to manually turn on and off the “driver only” button when you have passengers.
    I will mention that heat pumps are standard on Canadian spec vehicles of the competition that you mentioned above.
    And the radiant heat isn’t new btw. Mercedes introduced it a few years ago on the S-Class coupe (discontinued) and S-Class sedan in the form of heated door panels and armrests.
    Merkey likes this.
