2022 Prime donut
Discussion in 'Prime Main Forum (2017-2022)' started by simpske, Jun 25, 2025.
  1. BiomedO1
    BiomedO1 Senior Member
    4,547
    2,392
    Left Coast
    You can use the size chart comparison in thread #5 to determine the tire's overall diameter. I'm pretty sure a tire can vary about an inch in differential without affecting the car too much. Don't even talk to me about emergency handling situations, because the tire is a different sized and foot print on asphalt. If you take it easy and keep speeds below 50mph, you should be OK.
    FWIW: traction control tolerances are much tighter on AWD cars, so that the ECU can send power to the wheel with traction.
    #21 BiomedO1, Jun 28, 2025
