2022 Prius door auto-locking not working
Discussion in 'Gen 4 Prius Technical Discussion' started by rhfritz, Aug 19, 2023.
Tags:
  1. rhfritz
    rhfritz Junior Member
    33
    2018 Prius Prime
    I recently purchased a used 2022 Prius. The locking from the key fob works fine. But I've gone into Vehicle Preferences and configured it to auto-lock the door after 30 seconds (walk-away) as well as when I shift out of Park (vs at speed). Neither of those settings are working. Did I miss some other incantation?
  2. sylvaing
    sylvaing Senior Member
    1,219
    516
    If it's my 2017, that 30 seconds is when you unlock and fail to open a door within that 30 seconds, not walk away. I unfortunately have no walk away lock, which is stupid IMHO.
    Cartesian Bear likes this.
  3. Doug McC
    Doug McC Senior Member
    1,087
    428
    Midwest
    2022 Prius
    I have a 2022 XLE: If set correctly (as I have mine) your vehicle will lock when placed in D from P. However, the previous poster is correct on the “walk away” setting: it is only when you unlock the door and don’t open it that it will relock.
