2022 Prius Prime Dash Cam Install
Discussion in 'Prime Main Forum (2017-2022)' started by Kebisho1, Oct 24, 2021.
  1. Kebisho1
    Kebisho1 Junior Member
    16
    Massachusetts
    2022 Prius Prime
    Looking to identify a 20 amp switch controlled fuse to connect a dash cam to via a direct wire harness. I appreciate any tips you have. Thanks.
  2. Hajoca
    Hajoca Junior Member
    Vaughan
    2018 Prius Prime
    I used the 12volt cigarette lighter plug circuit for my set up.
  3. pghyndman
    pghyndman Active Member
    498
    464
    CT shoreline
    If you don't already have a dash cam you may want to consider a Fitcamx (see the review here). A thirty minute or less install, no wire routing to contend with, and professional looking results. We've got one and love it.
    bikeprof likes this.
