2022 prius prime hitch
Discussion in 'Prime Accessories and Modifications' started by Cavi, Dec 3, 2021.
  1. Cavi
    Cavi New Member
    Red Bluff Ca
    2022 Prius Prime
    so I am looking for a 2 inch hitch that will fit my prius prime. Torklift makes one my they only list it from 2017 to 2020, not for 21 or 22 yet. Anyone know if there is any difference in the frame stuff that would make it so it would not fit a 2022?
  2. MTN
    MTN Active Member
    287
    262
    SB, CA
    I don't believe there were any substantial / structural changes between the years. 2020 had the 5 seat layout that has carried forward. Other changes were for android auto and minor things like that.
    I would recommend installing some Air Lift 1000 bags, if hanging any weight off that hitch - like a cargo box or bikes. The rear end sags with a full load of cargo even. The bags are a pretty easy DIY and cost effective. I had a set on my VW for 5-6 years and never any problems and kept the car from sagging when loaded down with heavy gear. Otherwise you'll lose precious ground clearance in the Prime and add headlight glare towards oncoming traffic.
    I'm perplexed why all modern cars still sag when you are simply loading them with their rated cargo capacity. I guess that most miles are single driver and second most, single passenger, so beefier rear springs would gather too many ride compliance complaints.
  3. Fleabiscuit
    Fleabiscuit Junior Member
    42
    22
    Los Angeles
    I'm interested in seeing your set up once installed. I'm contemplating on buying a Prime to REPLACE my 4runner due to fuel costs and MPG (and also going back into the office next month). Wife and I both MTB, so I would like to how much sagging there is when its loaded with two bikes!
  4. Michael Fang
    Michael Fang Junior Member
    17
    23
    Orange County, CA
    Here's my 2" Torklift hitch on a 2021. I also installed the 1.5" lift kit. 20211117_203020.jpg 20211211_153149.jpg 20211211_153112.jpg
    Steve Pease likes this.
Loading...
