2022 Prius Prime Limited tires
Discussion in 'Prime Fuel Economy & EV Range' started by Richard Schraudner, Aug 25, 2022.
  1. Richard Schraudner
    Richard Schraudner Junior Member
    NYC
    I find myself the happy owner of a week old 2022 PPL having moved up from a 2012 Hybrid Prius. There’s plenty going on, and I have so much to read here. Big thanks. I know the value of first rate tires, and Dunlop had scorned for poor wet pavement performance. Worse for snow & ice. Still true?
    Q 1. What is the undeniable best tire (I’ll likely have my grandchild in the car).
    Q 2. blizzaks still best for snows.
    Q 3. At the moment plug in charging is not possible. I do see street chargers but what to do fo 2 hours. That said I get a popup when I shutdown that the car would like a;*IMMEDIATE* plug in charge. What if I don’t or can’t) make that happen. Any downsides to just driving like a Prius?
    lots of fun.
  2. schja01
    schja01 Senior Member
    1,868
    1,236
    Chicagoland
    2024 Prius
    Limited AWD-e
    Can’t say I’ve ever got that message even with 0% charge.
    There should be no issue driving it like a normal/non-plug-in Prius.
  3. Mendel Leisk
    42,337
    How many miles on it? Hopefully not brand new and you're looking to swap the tires immediately. I wouldn't write off an entire tire company without giving what you've got a chance, well unless you've acquired Walter White's slush fund.
    Regarding question #1: In 15" my pick would probably be Michelin Defender T+H (believe that's the current suffix). I'm sure it's deniable, just my pick.
    Regarding question #2: The best snow tire might not be the best snow tire. Appreciate that might not make much sense, but hear me out: the "best" snow tire, something that can do slaloms on ice rinks, may have terrible bare pavement manners. Anyway, my pick: Michelin X-Ice Snow, for a decent traction snow tire that that has the sound levels and feel of a competent all-season. For a utilitarian rim, I went with:
    Corolla steel rim, part no: 42611-02471 (2003-2008 corolla or matrix, CE, LS, S)
    steel rim lug nuts, part no: 90942-01007 (plain, open-ended, galvanized)
  4. MalachyNG
    MalachyNG Active Member
    304
    227
    Northern NY
    2022 Prius Prime
    Q1 - as I'm sure you noticed there are a lot of threads about tires. It really comes down to personal choice. For a softer ride or better traction you'll have to settle for lower gas mileage. What kind of things are important to you? Gas mileage? Road noise? Traction?
    Q2 - snow tires have been getting better over the years and a quality set from any of the major manufacturers will do you fine. I've had good experience with both Blizzaks and Michelin's X-Ice. The best advice I've gotten is to buy a set of rims for your snows so you can swap them yourself instead of waiting for an appointment at a tire shop. In 2020 I ruined a set of x ice after only 1 season because I couldn't get into the shop to switch them until mid May.
    Q3 - works just fine in hybrid. When I can't plug in I'm still getting better mileage than the 2016 regular Prius it replaced. I wouldn't go out of my way to charge on a road trip mainly because of the time it takes and how few miles it goes in EV. But if there's a free charger (many Chargepoint offer 2 hours free) someplace I'm going to be at for a little bit anyway I'll plug in.
  5. Gokhan
    Gokhan Senior Member
    6,714
    2,661
    Paramount CA
    I highly recommend the Dunlop Enasave 01 A/S OEM tires that came with my 2021 Limited! They handle much much better than the Toyo NanoEnergy A41 OEM tires that came with my 2020 XLE. The fuel economy is great, too.
  6. Mendel Leisk
    42,337
    Depends what you mean by "best". Blizzaks may be "best" for deep snow traction, but if you're running in a mix of conditions, often on clear pavement, the Michelin X-Ice, while they may give up that nth degree of traction, might be quieter/smoother option.
    I'd second getting them mounted on separate rims. See the Corolla rim link in my signature for what I'm using.
    Merkey and Salamander_King like this.
  7. Salamander_King
    Salamander_King Senior Member
    11,024
    8,978
    New England
    I recently received a promotional e-mail from Michelin. I think they are now moving to Defender2?
    MICHELIN Defender2 - Car Tire | MICHELIN USA
    EDIT: looking at the Michelin site, Defender2 is not available in 15". Defender T+H is still available in 195/65R15 for a PP.
    MICHELIN Defender T + H - Car Tire | MICHELIN USA
  8. Gokhan
    6,714
    2,661
    Paramount CA
    I would steer away from non-OEM tires. You're probably looking at an mpg loss ~ 5 mpg with a non-OEM tire, as there are very few good LRR tires out there.
    As I said, Dunlop Enasave 01 A/S OEM tires handle well and get good fuel economy.
  9. Salamander_King
    11,024
    8,978
    New England
    I like Dunlop Enasave 01 A/S OEM tires on PP when they are new. But it can get very loud and uncomfortable as they age. I had OEM Dunlop Enasave on my 2017 PP and drove ~30K miles on them. They were all down to 4/32 tread when I sold the car. At that rate, the tires would have hit the legal limit of 2/32" by 45K miles. On top of the shorter tread life, they do not handle ice and snow in my climate. Any savings I may get from fuel, I will blow on the early purchase of the new tires.
    With my current mileage, I probably will not need to purchase a set of tires for my PP before I switch. But if I have to buy new tires, it is not going to be Dunlop Enasave or any of PP OEM tires for sure. For much less price, I can get decent tires. If I am going to keep the car for a long time, then longer tread life and comfort and ice/snow tractions are the higher priority than mpg. If trading is imminent, then I will probably buy the cheapest set of tires. I don't have any experience with after-market tires put on my PP. I had Dunlop Enasave 01 A/S OEM on the 2017 PP and the current 2021 PP. The 2020 PP came with Made in Japan version of Ecopia EP422 plus, but I only drove 4K miles before selling it, so I can't say much about the longevity of the tire.
    For my previous cars, Gen3 and HCH, I liked Conti True Contact and Yokohama Avid Ascend. There was no mpg loss from the OEM tires I switched. And they were both long-lasting, comfortable, and handled ice/snow well.
    #9 Salamander_King, Sep 29, 2022
    Gokhan likes this.
  10. Bootney Lee Farnsworth
    Bootney Lee Farnsworth Junior Member
    Ladera Ranch, CA
    I believe the message you're seeing just means that the car will charge immediately after you plug it in vs. plugging in now and the car is scheduled to charge later (if you had entered a time you want a charge to start or end).
  11. schja01
    1,868
    1,236
    Chicagoland
    2024 Prius
    Limited AWD-e
    Bootney Lee Farnsworth | PriusChat is correct. That charge immediate message is a button that toggles each time you touch it between immediate and scheduled charging when you attach the charging cable to the charging port.
  12. Zed Ruhlen
    Zed Ruhlen Active Member
    247
    138
    Hood River, OR
    2018 Prius Prime
    Interesting that you chose the Prime if you can’t plug in. The downsides would have made me choose the regular Prius in that case. I plug mine in from the outside Christmas lights outlet at my house. But if I didn’t have the ability to charge the regular Prius would be a much better option. Bigger cargo area, rear wiper, spare tire, and better fuel economy.
  13. Gokhan
    6,714
    2,661
    Paramount CA
    That's just a generic message reminding that the car is a plug-in hybrid.
    I would at least occasionally charge it. Keeping the battery at a very low SOC all the time is probably not good for it. Ideal SOC for battery life is around 30%.
  14. Richard Schraudner
    NYC
    My first Car was a 1970 Triumph Spitfire where I was able to get out of the (then) notoriously poor Wet Handling Dunlops. I wound up with an Austrian Tire that was like glue in the pavement in all conditions. I’ve been dubious on Dunlops since. That said the 2022 Prius has been an easy drive and no squeaks out of the Dunlops. I went with Blizzaks for the Winter. Last few years only needed a few times but one involved a quick trip to an emergency room with 2” of fresh snow. Hope for the best, but that night the worst, with no slide but witnessed a bunch of wipeouts.
    The new ones are tempting but the dash visibility is a show stopper for me.
    2022 Prime Limited has a few Blemishes like the wireless charger cuts off after 15 seconds, rear ventilation is useless with a vent under seats, UI on screen not a great experience. Overall love the car so these are minor considerations. Not my first Prius.
  15. Richard Schraudner
    NYC
    Reality was that at the time there were chip shortages and there was talk that Prius orders were 18 months backordered. I got a call from my salesman and Yada Yada, a 10 hour marathon I’m in a Prime Limited. Besides the plug in option the trim allowed for an HUD which I really like and use. Car has been a nice experience.
  16. Richard Schraudner
    NYC
    I had the Continental Contis on my Gen 3 and was very happy. Good call.
  17. Mr.Vanvandenburg
    1,359
    659
    2020 Prius Prime
    The plugshare or chargepoint apps show most of the stations if you haven’t used them already. Some should be free.
    Then there are people who know every free wall plug in every place in town that will allow using it. The fringe charging people.
    Yes the immediate thing is a choice if charging starts immediately or on a schedule. .
