2022 Reverse Beeping gone?
Discussion in 'Prime Main Forum (2017-2022)' started by Marine Ray, Sep 23, 2021.
  1. Storm88000
    Storm88000 Active Member
    321
    145
    LHValley, PA
    2020 Prius Prime
    Does my 2020 LE have this? It makes a ton of beeping noise in reverse but I thought that was just inside the cabin. Did it start after or is it in the higher trims?
  2. Storm88000
    321
    145
    LHValley, PA
    2020 Prius Prime
    Here's the advice a biologist and conservationist told me about the issue with driving and deer in the road:
    If you can't avoid one, try to aim for its rear, because as he said "animals RARELY back up in the wild."
    Trollbait likes this.
  3. Trollbait
    12,806
    It is separate from the beeping. All EVs are required to make a noise at low speeds.
    Storm88000, don_chuwish and Ovation like this.
  4. Storm88000
    321
    145
    LHValley, PA
    2020 Prius Prime
    I don’t think mine does at low speeds. Not the 2020 at least
  5. Gokhan
    Gokhan Senior Member
    6,698
    2,651
    Paramount CA
    It makes the sound even at zero speed when you put the gear selector in D or R. Roll down your windows and shift from P to D or from P to R to hear it. It is easier to hear it in a garage. It sounds like a soft grinding sound.
  6. Storm88000
    321
    145
    LHValley, PA
    2020 Prius Prime
    wow. And this is for all trims 2017 and up? I honestly never noticed it. I’ll have to try it
  7. Trollbait
    12,806
    It might be earlier, and it is for all EVs. Now, pre2017 models may of had an option to turn it off.
    Storm88000 likes this.
  8. MalachyNG
    MalachyNG Active Member
    304
    227
    Northern NY
    2022 Prius Prime
    I've noticed that when at a drive thru.
  9. robAlatte
    robAlatte Member
    60
    40
    Palm Springs, CA
    I can confirm that the reverse beep is totally gone on my 2022 Prime. My 2021 Prime has the beep. There is no single beep, just no beep at all.
    Downrange and Marine Ray like this.
  10. GSP_Prius
    GSP_Prius New Member
    2022 Prius Prime
    No reverse beep but I have a faint beeping from back seat maybe when driving in eV mode only. Like 1/1000 sound of the backup beep. 2022 Prius prime
    yes the eV wind sound at low speeds
  11. Joe Cowie
    Joe Cowie Junior Member
    39
    22
    Calgary, Alberta,Canada
    ----Canada----
    I drive a 2022 prime. Where is the speaker located and how did you get to yours?
  12. Colorado Boo
    Colorado Boo Active Member
    307
    202
    Monument, Colorado USA
    2021 Prius
    LE AWD-e
    Mine is in front of the radiator, just to the right of center after you remove the top plastic cover. It's held in by one bolt (14mm I believe). I think the newer Toyota's are even louder...a neighbor has a new Rav4 Hybrid and I can hear the UFO speaker when he drives by the house...ridiculous!
    Joe Cowie likes this.
  13. Downrange
    Downrange Active Member
    373
    214
    2024 Prius Prime
    SE
    2022 Prime - yes, the reverse "garbage truck" beep is gone.
    PaulDM likes this.
  14. Paul Gregory
    Paul Gregory Senior Member
    2,338
    612
    Alberta
    2024 Prius Prime
    XSE
    2024 here. I'm sure I have no sort of reverse alarm, like I had in my Gen 3. I saw no settings for it in my setup screens.
    I never thought it was necessary anyway. Who needs to rely on others to see you when you're backing up? Conventional cars are just as inconspicuous to pedestrians when they are backing up anyway.
  15. Mendel Leisk
    42,266
    The reverse beep implementation was to “remind” you that you’re in reverse, a compensation due to the uninformative, return-to-centre shifter.
    It doesn’t work that well for me; more than once I’ve lost track of which direction I’m going to go when pushing the gas pedal. Luckily haven’t had any disasters yet.
    The traditional automatic shifter is much better in that regard; I never messed up with it.
    Louis19 likes this.
  16. Louis19
    Louis19 Active Member
    395
    370
    Laval Québec Canada
    2022 Prius Prime
    Upgrade
    Yep , the return-to center shifter has induceed me a new habit of checking the D or R indicator on the Dash before releasing the brake pedal ,also listening for the UFO sound , it is twice as loud in Reverse . No backup beep beep on the 2022 Prime
  17. Paul Gregory
    2,338
    612
    Alberta
    2024 Prius Prime
    XSE
    Why was the reversing beeper speaker on the outside of the car, if it was to remind the driver of being in reverse?
  18. Louis19
    395
    370
    Laval Québec Canada
    2022 Prius Prime
    Upgrade
    IIRC the beep beep was generated inside the car
