2023/4 Prius Prime vs. used Volt?
Discussion in 'Gen 5 Prius Main Forum' started by hill, Nov 20, 2023.
  1. KMO
    KMO Senior Member
    2,025
    747
    Finland
    2023 Prius Prime
    As I said, a valve-gated refrigerant path through the battery pack. IIRC the only other dedicated component is an expansion valve. It uses the same heat exchangers and compressor as the cabin AC/heat pump.
    Yes, the Gen 4 cools the cabin to cool the battery when charging. (Presumably the battery just has to lump it if you set cabin temperature to MAX while driving...)
    #21 KMO, Nov 20, 2023
  2. Gokhan
    Gokhan Senior Member
    6,686
    2,651
    Paramount CA
    Could you post a pic of the system?
    hill likes this.
  3. KMO
    KMO Senior Member
    2,025
    747
    Finland
    2023 Prius Prime
    Not got a live subscription, or a saved copy, I'm afraid. Working from memory...
  4. hill
    9,008
    ok ... sure ... if relatively poor means 42mpg vs 47mpg EPA highway. 10 or 11% ? Heck most of us here can do a bigger percentage just from one refuel to another turning on weather or how fast you need to get to where you might be going &/or how far &/or outside temps.
    "Real hybrid" ? Please elaborate
    Maybe folks don't realize what a real hybrid is by that statement. The volt is classified as both a serial & parallel hybri-turning on state of charge &/or what speed is traveling. If you even know the difference - maybe you could provide a link so we can clear up the confusion?
    #24 hill, Nov 20, 2023
  5. Gokhan
    6,686
    2,651
    Paramount CA
    I'll take what you said with a grain of salt then.
  6. Trollbait
    12,799
    o_O Do you even know what a Chevy Volt is?
    It is a full, power-split hybrid.
    For much of its history, the Prius was a high outlier for efficiency. The gen2 Volt's ratings are comparable to other hybrids and PHEVs of the time. https://www.fueleconomy.gov/feg/PowerSearch.do?action=PowerSearch&year1=2016&year2=2019&minmsrpsel=0&maxmsrpsel=0&city=0&highway=0&combined=0&cbvthybrid=Hybrid&cbvtplugin=Plug-in+Hybrid&YearSel=2016-2019&MakeSel=&MarClassSel=&FuelTypeSel=&VehTypeSel=Hybrid%2C+Plug-in+Hybrid&TranySel=&DriveTypeSel=&CylindersSel=&MpgSel=000&sortBy=Comb&Units=&url=SearchServlet&opt=new&minmsrp=0&maxmsrp=0&minmpg=0&maxmpg=0&sCharge=&tCharge=&startstop=&cylDeact=&rowLimit=50
    In general, PHEVs can't match BEVs in mpge.
    2016 Chevrolet Volt Premier Review & Test Drive – GM’s Hybrid Electric Gets Amped Up : Automotive Addicts
    bisco and hill like this.
  7. hill
    9,008
    Really?
    Then what is this;
    Hate to say it - but knowledge credibility is dropping quick here.
    Where do you get this stuff
    Don't feel bad I've had my own major faux pas over the decades of PC posts
    Maybe publicly repost your apples to oranges comparison?
    #27 hill, Nov 20, 2023
  8. Mr.Vanvandenburg
    1,359
    636
    2020 Prius Prime
    The Volts are hatchbacks. The second Volt was a different hybrid system than the first Volt and more like the Prius I believe. They were very different drives the Volt 1 & 2.
    Only the 2019 Volt had higher level 2 charging and it was optional if I remember. Hard to find one of those. The level 2 is about the same rate as the Prime for the rest of them. Volt 2 was 3.8 kw or something just a little higher, or maybe it was 3.6.
  9. hill
    9,008
    Memory is close but no cigar. If you got the upgraded volt with all the features you automatically got 7.2 kw. If you wanted 7.2 with the cheap version you had to order it. There are a decent number of the minimal optioned version that have 7.2 KW Chargers. Production (for 2019) was for roughly ½ ayear.
    That said it's very cool to get virtually full charge in 2 hours + or minus
    All in all (& the whole point of the OP) these 2 vehicles (latest versions) seem very close in features other than the many years apart that they were produced. This isn't stated to bug people that recently bought a new Prius Prime. They are certainly great vehicles to be sure. Maybe it's a question of whether or either the Volt was ahead of its time or whether the features of the current Prius Prime is passe? iduno - but from reading articles & people that comment on the 2 vehicle's similarities - they don't seem to be very far off in their features. kinda surprising there aren't folks here that might see that to some degree.
    #29 hill, Nov 20, 2023
    Trollbait likes this.
  10. bisco
    52,742
    that volt hatch looks huge, hard to believe it is smaller than gen5 prius
  11. Gokhan
    6,686
    2,651
    Paramount CA
    A joule per coulomb like any other volt?
  12. Gokhan
    6,686
    2,651
    Paramount CA
    Meh, my Gen 4 Prius Prime gets 54/42 − 1 = 29% better fuel economy than what it gets. So, I consider mine as the real hybrid. ;)
  13. hill
    9,008
    Certainly everyone is entitled to their opinion even if it's wrong. Apparently Toyota Manufacturing feels that the Gen 5 is better than the 4 no matter what. Sorry about the 4 - but it's never coming back. Still, glad it works for you
  14. KMO
    KMO Senior Member
    2,025
    747
    Finland
    2023 Prius Prime
    Aye, just as well. For all we know without definitive NCF screenshots, the G5 might not be a hatchback or a real hybrid either.
    Trollbait, hill and bisco like this.
  15. Gokhan
    6,686
    2,651
    Paramount CA
    Post it when you have definite information instead of a vague recollection of something that you might have seen.
    I have the Gen 4 NCF.
  16. Gokhan
    6,686
    2,651
    Paramount CA
    No matter what the haters say, Gen 4 Prius Prime is a great car, and I have the top trim. Gen 5 Prius Prime SE, which is the only trim I would be interested in because of the fuel efficiency and BEV range, misses several nice features my top trim has.
    "Better no matter what??" Whatever that means. I don't need the higher power and marginally improved handling of Gen 5 Prius Prime. I can care less about the looks. In fact, I like the headlight and taillight design of mine better. I keep repeating it: The only appeal in Gen 5 for me is TSS 3.0. Some want it for the looks, which is OK. Others want it because they don't have a car. You don't want it at all because you are a Tesla fanboy—yet, you keep posting in a Prius forum—which is also OK.
    #36 Gokhan, Nov 21, 2023
  17. KMO
    KMO Senior Member
    2,025
    747
    Finland
    2023 Prius Prime
    Why should I (or anyone else) ever want to do anything for you?
    If you care that much, get the Gen 5 NCF yourself; don't ask people on here for information then reject it when freely given.
    Trollbait and hill like this.
  18. Gokhan
    6,686
    2,651
    Paramount CA
    That's a very bizarre post—as bizarre as your previous one. No one is asking you to do anything, and there is no reason for such posts. Civility is appreciated more than anything in this forum.
  19. hill
    9,008
    thankyou once again - taking another thread's topic (comparisons of similar features of a brand new-longer range small-ish plugins) & making it about perceived hate of your car. Perhaps someone will start a thread in FHOP about "coffee cups" .... & yet somehow it'll still be possible to point out it's all about imaginary haters of your unrelated to the topic car.
    Roqu3 and Trollbait like this.
  20. Trollbait
    12,799
    They had the same system, just general improvements over time. I believe it dates back to an EV1 PHEV concept.
    It had a planetary gear set like the system in the Prius. Where the engine and motors connected into was different. There were clutches to allow better EV performance, which Toyota added in the gen4 Prime.
    It isn't. Chevy listed it as 10.something cubic feet, but the EPA has it as 19. Supplying cabin and cargo volume for actual cars to the EPA is a legal requirement. That makes the 19 the total cargo space. The 10 is probably the space without blocking the back window.
    If we used your definition of hybrid, the segment's sales would look a whole lot worse.
    :ROFLMAO:
    How about you post evidence that the gen5 NCF reads just like the gen4 as you claimed.:)
