2023/4 Prius Prime vs. used Volt?
Discussion in 'Gen 5 Prius Main Forum' started by hill, Nov 20, 2023.
  1. bisco
    52,863
    i think the biggest disappointment over at bolt.org (many users went from volt to bolt) after cancellation of volt was that gm didn't apply it to other models like toyota did to increase mpg.
  2. hill
    9,039
    It would seem that neither GM's voltec system nor the Prius Synergy Drive will ever scale up to a large system that would be necessary for 14,000 pound towing capability like the soon to be available Dodge plug in hybrid pickup. That seems surprising - this type of bigger vehicle just now coming out - because isn't the big truck market where the real big profit margins are with vehicles?
    #62 hill, Nov 24, 2023
  3. Trollbait
    12,831
    There was the Malibu full hybrid using it here.
    The Voltec scales up to Two-Mode, and HSD can be mated to an automatic transmission as seen in a couple RWD Lexus.
    The former didn't last long. Maybe it was too soon for the market. Cost of the system compared to fuel prices should be more favorable now. Though I recall it still having lower tow ratings than ICE models. I think it is still used in buses.
    The later never made it into a truck. Toyota ended up doing what Ford and Hino did, and use a parallel hybrid.
    Looks like GM is passing on full hybrids for now, and going with EVs. Down sizing the battery, and installing a generator for a PHEV is lower cost than developing a truck worthy hybrid system that may be of limited use in a plug in world.
  4. Pri3C
    Pri3C Active Member
    183
    131
    Midwest
    2014 Prius c
    Has it been mentioned how cramped the Volt’s headroom and legroom is in the back? At least that was my experience when I test drove one in 2020. I know there’s less headroom with the Gen 5’s design, but surely it can’t be as tight as the Volt’s.
  5. Trollbait
    12,831
    In inches; rear head, shoulder, hip, leg
    Volt; 35.8, 53.2, 51.3, 34.7
    PP; 36.4, 52.8, 51.7, 35.9
    Site Maintenance
    That's a link to the 2019 Volt press release.
    Pri3C likes this.
  6. The Tramp
    The Tramp Italian Prius Expert
    376
    52
    Turin, Italy
    2020 Prius PHV
    That's why I just bought mine second hand.
    Facts says that Gen 4 has better aerodinamics than the Gen 5.
  7. hill
    9,039
    link to those facts?
  8. Trollbait
    12,831
    Cd on the Toyota spec page is listed as 0.27 and 0,29 for the higher trims. Gen 4 was 0.24.
    The lower roofline of the gen5 means a smaller frontal area, which gets the CdA close to the gen4.
  9. KMO
    KMO Senior Member
    2,031
    751
    Finland
    2023 Prius Prime
    I've never seen 0.29 for the G5, just 0.27.
    Okay, checking now, I can see 0.29 on Toyota USA's web page for the Prime XSE and XSE+, but not the XLE or Ltd. Looks like we've got an anomaly here - I do not believe the PHEV has significantly worse Cd than the HEV (and enough to also be worse than every other Prius since the G1).
    Plus it's 0.25 for the G4 PHEV, compared to 0.24 for the HEV.
    If we assume the 0.29 is an error (although where did it come from?), then 0.25 versus 0.27 isn't that big a difference. Nevertheless my rough calculations still don't show the lowered roof of the G5 quite making up the difference in overall CdA though - I get roughly 0.59 (G4) versus 0.61 (G5).
  10. hill
    9,039
    and .28 for the Volt .... which was part of the observation of similarities. So however you slice it - these are minuscule amounts of drag difference between the vehicles.
    #70 hill, Nov 25, 2023
  11. Trollbait
    12,831
    Odd, I'm seeing the trim difference in Cd for both models at the site on my end. It was also mentioned in some articles on the release and reveal. Seems too high to be explained by the aero to normal wheel design difference. The increased(half inch) ground clearance with the larger wheels could allow under flow air to get more turbulent. It would increase the frontal area, but that won't show in the Cd.
    Some reports for the gen4 Prime had it as 0.24. A rounding error can explain the difference in reports. Toyota did state that the Prime's front increased drag, and the rear countered it. Which is more than we got with the gen5 difference.
    When asked about the increased Cd, a Toyota rep said the smaller frontal area made up for it; no numbers. A CdA calculation of the squared front profiles doesn't show much improvement in closing the gap, but the actual trapezoid measurements could get them closer.
