2023 Global Hurricanes and Typhoons
Discussion in 'Environmental Discussion' started by tochatihu, May 26, 2023.
  1. tochatihu
    tochatihu Senior Member
    9,964
    3,846
    Kunming Yunnan China
    2001 Prius
    Abandoning a N Atl focus this time. Later posts will summarize what is expected for N Atl this year. Briefly in advance ... average. El Nino (ENSO positive) is generally associated with low action in N Atl, but ocean waters seen unusually warm everywhere, so surprises are surely possible. I was in on the surprise of 1998...
    Anyway 2023 has had Ilsa in Australia, Mocha in Myanmar Bangladesh, and Mawar in Guam as large ones so far. Each has been unusual in time or space, but one-year action is not climate change. You know.
    Mawar has passed Guam and is generating divergent model forecast paths
    https://www.tropicaltidbits.com/storminfo/02W_geps_latest.png
    Assuming central among those, recurvature and offshore Japan etc. A lot of near-surface ocean mixing happens, so this might be a apt time for Fukushima to send their radioactive water out there. Dilution. But I do not know if all needed approvals have been given. They may hold their water a bit longer, but 200 hours later will be a dilution by mixing party party party.
  2. tochatihu
    9,964
    3,846
    2001 Prius
  3. tochatihu
    9,964
    3,846
    2001 Prius
  4. tochatihu
    9,964
    3,846
    2001 Prius
    Baja California and USA California to the north, say hello to Hurricane Hilary (just one l). Winds will be mostly expended by the time of border crossing, but an unusual amount of rain is predicted.
    Whatever does not flood away will have swell desert floral displays later.
  5. bwilson4web
    16,523
    And wild fires after that.
    The head of the FDA should arrange a conference with state and local emergency service leaders on how to deal with high winds and fires. Then include floods. Maui is just a wake up call from Mutha Nature.
  6. tochatihu
    9,964
    3,846
    2001 Prius
  7. tochatihu
    9,964
    3,846
    2001 Prius
    Meanwhile in the North Atlantic, not much is going on. By the end of next week, one of 3 global models shows a strong compact storm coming off 'the right spot' in Africa. Other models show nothing.
    But storm watchers are doing Hilary right now.
  8. bisco
    52,812
    had some serious tornadoes here over the last few days
  9. tochatihu
    9,964
    3,846
    2001 Prius
    You will not soon see another rainfall forecast like this:
    HURRICANE HILARY
    Remember Bristlecone pines? Those trees hovering on the edge of death for thousands of years? Something like this may touch them a few times. Or only once.
  10. bisco
    52,812
  11. tochatihu
    9,964
    3,846
    2001 Prius
    Yes Tropical Storm Idalia will bring a lot of rain to FL panhandle Weds/Thurs. Then GA, SC. Trop storm/hurricane distinction is based on wind field and minimum pressure. A trop storm can rain more than a hurricane, if it sets up right.
    wxman likes this.
  12. tochatihu
    9,964
    3,846
    2001 Prius
  13. bisco
    52,812
  14. tochatihu
    9,964
    3,846
    2001 Prius
    I suppose Hurricane Hunters are bumping around in Idalia and dropping dropsondes right about now.
    Various models show a wide range of predictions from staying as a TS, all the way up to cat.3 at landfall. That's a lotta pasta.
    FL panhandle airfields (mil and civ) ought to to be reposiitoning aircraft now? Jacksonville and Tampa look like tossups. Hoping they don't toss up.
    Watercraft harbored along there - sail west. Unless operators are driving away instead. So let insurers deal with it?
    Drivers, avoid using gasoline contaminated with diesel. Now a thing in FL, new innovation for this event.
  15. bisco
    52,812
    maybe if they keep coming people will give up on the idea of rebuilding, only to get blown away again
  16. bisco
    52,812
  17. bwilson4web
    16,523
    Local TV weather reporter stated the high temperature extends relatively deep in the Gulf of Mexico. So there won't be any mitigation by cold water upwelling.
  18. tochatihu
    9,964
    3,846
    2001 Prius
    Upper level wind shear is leading diff models to diff predictions.
  19. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    Thanks for asking.
    Sorry for the late reply. We took the extreme precaution of moving the lawn chairs inside. At the moment, there's another rain band passing through. I slept peacefully through the brunt of the storm. Nothing exciting happened. Oops! The rain just stopped again. It's like God's throwing the switch on and off. :D
    Time to head out for a meeting about 20 miles away. I'll see what I can see along the way. No damage expected. Once again the Bay Area dodges a bullet.
  20. bisco
    52,812
    Glad to hear it!
    we’re getting rough surf from Franklin
    #20 bisco, Aug 30, 2023
    jerrymildred likes this.
