2023 Prime battery: maker, chemistry, form factor?
Discussion in 'Gen 5 Prius Technical Discussion' started by Maxwell61, Jun 15, 2023.
  1. Maxwell61
    Maxwell61 Active Member
    393
    242
    Italy
    2024 Prius Prime
    XSE Premium
    mountaineer likes this.
  2. Maxwell61
    393
    242
    Italy
    2024 Prius Prime
    XSE Premium
    Yes, i can confirm. In the Japanese brochure is specified for the battery 51 Ah.
    So they are the new Panasonic NMC 622 cells prismatic as presented by PUSHEV.
    New cell (in use since 2020)
    • Manufacturer: Panasonic
    • Capacity: 51 Ah
    • Nominal voltage: 3,7 V
    • Energy: 188,7 Wh
    • Form factor: PHEV2
    • Chemistry: NCM 622
    I can calculate there are 72 cells: 51 x 3,7 x 72 = 13,59 kWh.
    PHEV2 prismatic battery cell standard
    • Length: 148 mm
    • Height: 91 mm
    • Thickness: 26,5 mm
    Already in use in:
    • Toyota C-HR EV with 288 cells (96s3p): 288 x 51 Ah x 3,7 V = 54,3 kWh
    • Lexus UX 300e with 288 cells (96s3p): 288 x 51 Ah x 3,7 V = 54,3 kWh
    • Toyota RAV4 PHEV with 96 cells (96s1p): 96 x 51 Ah x 3,7 V = 18,1 kWh
    • Suzuki Across with 96 cells (96s1p): 96 x 51 Ah x 3,7 V = 18,1 kWh
    Good news for the durability of those cells:
    "The Lexus UX 300e comes with a 10-year or 1 million km battery warranty, which only says good things about this new prismatic battery cell from Panasonic."
    "Not surprisingly, the Honda e and Mazda CX-30 Electric also use this battery cell,"
    #2 Maxwell61, Jun 18, 2023
  3. Gokhan
    Gokhan Senior Member
    6,633
    2,633
    Paramount CA
    My Gen 4 Prius Prime after 140 charging cycles has virtually 0% capacity and range loss. I baby it though (scheduled charge, no heavy acceleration or extreme speeds). I wouldn't worry about the Toyota battery packs as long as you baby them.
    Maxwell61 likes this.
  4. Trollbait
    12,745
    PHEVs in general tend to baby the battery. Not only can the system shift to the engine when the battery could be stressed, but the battery itself falls under emission control warranty requirements. Manufacturers don't want to pay for replacements during the federally mandated warranty period.
  5. Gokhan
    6,633
    2,633
    Paramount CA
    You get a lot more charge/discharge cycles due to the lower battery capacity if you drive a PHEV like a BEV though.
  6. Trollbait
    12,745
    My comment isn't about what the driver can do, but what the car can do, without the driver's permission. Take a hot day, a PHEV can fire up the ICE to reduce heat build up in the battery from discharging. That is not an option for a BEV's system. The PHEV can avoid high stress points on the battery with engine use, whereas the BEV would just have to 'suck it up'.
  7. Gokhan
    6,633
    2,633
    Paramount CA
    Prius Prime PHEV works as a BEV in the EV mode, with the ICE never kicking in except during defogger use in certain situations and in extreme-speed driving. There was one owner who reported the ICE kicking in during prolonged downhill regenerative braking, but that was about it.
  8. Maxwell61
    393
    242
    Italy
    2024 Prius Prime
    XSE Premium
    I've also found the specs for the cells. It mentions 2000 cycles (for DOD 100%), and many sources indicate a DOD of 75%, for the Prius, which will be some 3600-4000 cycles.
    #8 Maxwell61, Jun 23, 2023
    MAX2, Xeico, Exerted and 3 others like this.
  9. Gokhan
    6,633
    2,633
    Paramount CA
    That is an impressive cycle life!
    Cycle life greatly depends on the charge rate and discharge rate. You double or quadruple it or more if you use Level 1 instead of Level 2 and accelerate and decelerate gently and avoid fast speeds in BEV driving. DC fast charging is especially bad, but Prius Prime does not have it. Battery life also depends on how you store the battery. You should ideally store a battery at 30–40% SOC, and storing it at a high SOC is particularly bad. As for as the depth of discharge, I believe it is up to 87% at full HV-reserve depletion for Gen 5 Prius Prime.
    Exerted and Maxwell61 like this.
  10. Ansari
    Ansari Junior Member
    43
    2023 Prius
    I cannot find how to display the engine temperature. Any idea?
    How can I turn off hybrid system in 2023 Prius?
    #10 Ansari, Jun 27, 2023
  11. mountaineer
    mountaineer Active Member
    146
    115
    Hamilton, ON
    2019 Prius Prime
    I think you need something like ScanGauge II to show engine (or coolant in this case) temperature. I use that number to help me decide when to fire up the engine if the battery won't get me to my destination.
    If you mean how do you turn off hybrid mode to drive in EV mode, you hit the button beside the shift lever that says "EV mode" :)
  12. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    In the hybrid (regular Prius), you can not as that is basically the only mode it realistically operates in. There is a very limited EV mode function but it only works under very limited circumstances when temps, SOC, low speeds, distance, etc., parameters are all met. See owners manual.
    Prius Prime? See above.
  13. Ansari
    43
    2023 Prius
    Is there an option in 2023 prius you can see how many miles you drove on engine only?
    HacksawMark likes this.
  14. HacksawMark
    HacksawMark Active Member
    449
    318
    Oregon
    2023 Prius Prime
    XSE
    and/or hours
  15. tovli
    tovli 2023 Prius Prime replaced 09 Prius
    352
    275
    Boynton Beach, FL
    2023 Prius Prime
    XSE
    2023 Prime WALL to BATTERY LOSS?
    New 2023 Prius Prime owner, trying to get some understanding of the traction battery charging. Yesterday's charge (with Toyota Level 1 120v CCID) showed 1465W at the wall, while Dr Prius showed 1135W at battery (4.15A*273.5v), Battery temp 97degF. (It is stinkin' hot here in south Florida even in my garage at night.)
    Checking at various times in the charge seems to show I lose 25% to 29% to the charging power conversion, cable, heat, and battery cooling.
    Interested in what others are seeing
    AndersOne and Maxwell61 like this.
  16. pramodhrachuri
    pramodhrachuri Junior Member
    30
    2024 Prius Prime
    SE
    That could be due to the battery cooling running. Are you seeing similar numbers now in winter?
  17. RandyPete
    RandyPete Active Member
    409
    171
    Santa Margarita, CA, USA
    2024 Prius Prime
    XSE
    Where is the 2024 Prius Prime battery and battery charger located. How are they cooled/heated ?
  18. KMO
    KMO Senior Member
    2,015
    743
    Finland
    2023 Prius Prime
    Battery is on the bottom of the car in front of the rear suspension. You can see it on a lift here:
    The charger is inside under the expanded polypropylene bits in the back. You can see it in the pictures in the first post here:
    2023 Prius Prime | PriusChat
    Battery heats itself, or when plugged in there is 200-300W of electric heating it can use.
    Battery cooling is via the A/C refrigerant circuit.
    Charger is air cooled - there's a fan on top. Not clear to me how the air's ducted - presumably there's some shaping in the EPP and somewhere for it to go.
    #18 KMO, Feb 11, 2024
  19. RandyPete
    409
    171
    2024 Prius Prime
    XSE
    Thank You !
  20. Prius23years
    Prius23years Junior Member
    Derby England
    2021 Prius PHV
    Business Ed. Plus
    I have a 2024 Prius Plug-in Design Edition (UK option which has the 17" wheels). The full capacity of the battery is stated as 13.6 kWh by Toyota, so if the 87% discharge value at full HV-reserve depletion is correct that implies there is 13.6 x 0.87=11.8 kWh available for EV use with 1.8kWh being held in reserve for HV use. This seems in line with the battery size of most of the previous hybrid only Prius models, dating back to the original 2001 Classic Prius with its NiMH battery which was 1.8kWh, although I note that the Gen 5 hybrid only Prius which is available in the US but not in the UK or the rest of Europe only has a 0.91kWh battery accord ing to this review: https://www.motortrend.com/news/toyota-prius-hybrid-2024-car-of-the-year. As an aside I wonder why Toyota moved to a smaller battery on the latest hybrid only model? Obviously there'll be a slight saving in cost and weight, but I wnder if there's a downside in that the HV battery can't store or give out as much regen braking energy as previously?
    The 11.8kWh value for EV use also seems to be in rough agreement with the values of miles/kWh and EV range when fully charged that the car displays. It's currently showing a total average of 4.1 miles/kWh for EV use (I mainly use EV around town) so that would work out as a maximum range of 4.1 x11.8=48.4 miles, which agrees well with the displayed 48 miles max EV range when fully charged.
    One anomaly though regarding this is that the MyToyota smartphone app which communicates with the vehicle shows a battery charge status of 31% when the vehicle is down at zero EV range (obviously it shows 100% when fully charged). I can only surmise that the MyToyota app is showing an incorrect value of 31% battery charge status when the EV range is down to zero, because the previous discussion indicates it should be about 13%.
    #20 Prius23years, May 18, 2025
