2023 Prius accessories
Discussion in 'Gen 5 Prius Accessories and Modifications' started by Daturah, Mar 13, 2023.
  1. daisy555
    daisy555 Senior Member
    1,700
    697
    CT
    Thank you!
  2. Nicad
    Nicad New Member
    23
    ontario, canada
    2023 Prius
    Limited AWD-e
    In Canada, a yearly application of Rust preventative (Like Krown or Rust Check) makes a huge difference in the longevity of the body.
  3. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,800
    2017 Prius c
    OK, I'll give you that one.......kind of.
    For that to be effective, it must be started IMMEDIATELY when the car is new and then kept up.
    The benefit will be greatly reduced for a used car.
    Also you must keep the car more than something like 7 years because body corrosion usually doesn't
    show up until after that. So you would be doing the NEXT owner a favor.
    And all of that assumes that you will be using a product that is really good........instead of a product
    from a company that is really good at marketing HYPE.
  4. CATZKUN
    CATZKUN New Member
    CA
    2023 Prius
    MAZDA CX5, LEXUS UX200, TOYOTA CHR with same exact T145/90/D16 with bolt pattern 5X114.3 mm. 16x4T
    2023 PRIUS LE 195/60R17=26.2 in
    2023 PRIUS XLE 195/50R19=26.7 in
    Recommended size in manual T145/90D16=26.3 in
    Just ordered one. Hope it matches perfect.
    tovli and leftbrarian like this.
  5. CATZKUN
    CATZKUN New Member
    CA
    2023 Prius
    UPDATE) MAZDA CX5 spare tire matched perfect !!
