2023 prius..Hybrid Reborn, interview w/chief engineer Satoki Oya
Discussion in 'Gen 5 Prius Main Forum' started by samsprius1, Jan 25, 2023.
  1. samsprius1
    samsprius1 Active Member
    714
    175
    2023 Prius
    Limited AWD-e
    Satoki Oya the chief engineer for the Toyota Prius! Interesting insight to design and change. Enjoy.
    #1 samsprius1, Jan 25, 2023
  2. Salamander_King
    Salamander_King Senior Member
    10,976
    8,879
    New England
    Just an editorial. The chief engineer's name is Satoki not Satoko.
    You might want to edit it while you can.
  3. Tideland Prius
    16,211
    I've fixed it for them.
    samsprius1 and Salamander_King like this.
  4. Tideland Prius
    16,211
    lol. Akio Toyoda sees the Prius as a commodity. (but an important commodity).
    One thing I've noticed now that there are close up of the wheels, did Toyota change the Prius' wheel lugs to wheel bolts?
  5. Salamander_King
    10,976
    8,879
    New England
    Not sure. But if they are, then I'm sure that they know now how to put them on so that the wheel will not fall off.
    BTW, just read the news that Akio Toyoda is no longer the president of the company. He is now the Chairman... Whatever that means.
    #5 Salamander_King, Jan 26, 2023
  6. Trollbait
    11,682
    Pretty sure they went with the bolts. Heard the Crown uses them, and they are cheaper for the manufacturer. Unless, Toyota has other issues with them come up, expect all models to use them in time.
  7. Hammersmith
    Hammersmith Senior Member
    1,497
    1,511
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    According to the 2023 manual, they're nuts. (pg 498-9)
    Trollbait and Salamander_King like this.
  8. samsprius1
    714
    175
    2023 Prius
    Limited AWD-e
    I think it’s a good move for Toyota, giving it a lowdown coupe look is one of the best design features and the more powerful electric motor on the AWD is one of the best engineering will renew interest and sales !You have to admit the last few generations have been kind of stale looking when you compare it to a new Tesla,I too have owned a GEN2 and a GEN3 looking forward to this fifth generation. my wife’s currently driving a RAV4 hybrid I am convinced Toyotas doing everything right! going to be a good seller demand will be high for this one!! gas prices going up again.
  9. samsprius1
    714
    175
    2023 Prius
    Limited AWD-e
    LE might be different has wheel covers! everything else has the custom look alloy wheels?
  10. Trollbait
    11,682
    The bZ4X manual does spell out they are wheel bolts. No Crown manual available yet.
  11. Mendel Leisk
    38,982
    Yes. Unless it's a typo, supersceded:
    Isn't it more of a struggle getting a wheel on with bolts?
    But, but: corroborating @Tideland Prius, screen-grab from OP video (around 7:40):
    Another screen grab, earlier in video, a little clearer:
    #11 Mendel Leisk, Jan 26, 2023
    Tideland Prius and Trollbait like this.
  12. Trollbait
    11,682
    With the bolts there should be a pin that is put into the top hole to guide the wheel. A threaded rod will work if you have to replace the pin. Without it, yes it will be difficult. Not only do you have to hold the wheel up, but the brake rotor could spin out of alignment while trying to get holes and bolt lined up.
    The bZ4X manual instructions covers the procedure with the bolts. But I don't think I've ever seen a wheel lug/nut that could be fastened with a hex wrench. The Prius manual should have answered this, but we can't rule out a lazy or ignorant copy and paste.
  13. Hammersmith
    1,497
    1,511
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    The pictures certainly look like the bolts from the bZ4X. So it appears to either be a case of the manual reusing the text from the 2022 because they weren't informed of the change, or that the pre-production cars used for the press tour used components from the bZ4X or Crown and the production cars will go back to lug nuts. Like everything else, I guess we'll know when we actually see cars on the lots.
    Mendel Leisk and Trollbait like this.
  14. Gokhan
    Gokhan Senior Member
    4,808
    1,900
    Paramount CA
    Guys, look at the pictures carefully. You can see the wheel studs.
    So—thank God—It is not a bolt. It is a nut with a bolt-like head.
    Tideland Prius likes this.
  15. Trollbait
    11,682
    We did, and a close look of photos of the wheels of the review cars are showing bolts. The post before yours summed the situation up.
  16. Gokhan
    4,808
    1,900
    Paramount CA
    There is a 0.1% chance of the owner's manual being wrong.
    The pictures in the 2022 owner's manual are different.
    #16 Gokhan, Jan 26, 2023
  17. Salamander_King
    10,976
    8,879
    New England
    Well, it looks at least for the 19" wheels on the upper trims for North American models maybe using the lug bolts, not the nuts.
    Google Translate did not work on the page for me, but the article gives details on the wheels of the new Gen5 Prius and says it is a bolt at least the one they used for the test drive. (the top photo below)
    But the article also points out that the Gen5 Prius shown on the World Premium "looks" to be lug nuts. (the bottom photo below) So, the article reserves the possibility that both systems may exist depending on the models.
    https://prius-news.com/159472.html
  18. Gokhan
    4,808
    1,900
    Paramount CA
    Nah, they are probably nuts of different shapes. You can't have nuts on some but bolts on others. I don't think any reviewer has removed a wheel yet. I can't imagine Toyota using bolts on their flagship vehicle after what happened with the limited-production bZ4X.
    Salamander_King likes this.
  19. Salamander_King
    10,976
    8,879
    New England
    I don't think Prius is their flagship vehicle. But that is another topic. In any case, they did move to use wheel bolts on their new Crown. And I think for some Lexus.
    However, by doing more Google searches, you may be correct about the lug nuts being used on the Gen5 Prius. I have found several reviews and discussions on this topic, and they are as confused as we are in most cases. No one has actually seen the wheel taken off from the production models of Gen5 yet. We will know for sure very soon.
    Mendel Leisk and Gokhan like this.
  20. bisco
    49,811
    maybe someone in cali will stop in and take a look
    Gokhan likes this.
