2023 - Prius or Prime - spare tire?
Discussion in 'Gen 5 Prius Main Forum' started by Mark Monroe, Jan 3, 2023.
  1. Hammersmith
    Hammersmith Senior Member
    2,497
    2,562
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Are we sure about that? AFAIK, we know nothing about the Prime SE in regards to a spare. And there's conflicting official information on the LE spare. The November USA data sheet says yes, the current trim level comparison on Toyota's website says no. I don't think we'll know for absolute certain until LEs start appearing on lots and people pull up the floor tray.
  2. Gokhan
    Gokhan Senior Member
    6,717
    2,672
    Paramount CA
    Yes, Prius LE has a temporary spare according to the owner's manual.
    Prius and Prius Prime are the same car except for the battery size; so, I expect the same for Prius Prime SE.
  3. Hammersmith
    2,497
    2,562
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Careful, you're assuming facts not in evidence.
    While the odds are good that the LE will come with a spare, there is no absolute confirmation out there until we actually open up the back of an LE and look. The manual doesn't link options to trim levels, it just lists all possibilities. In the end, there's a chance Toyota will decide to not put a spare in the LE for some reason. But if a major customer(say Enterprise Rent-a-Car or something) came to Toyota and demanded a spare, Toyota could do that now and not have to change the manual for that one customer.
    And as for the Prime, we simply don't know yet if the sheet metal is different on the trunk floor because of the larger battery. We can hope it's the same, but I don't think we can assume yet until journalists get to drive around in the pre-production cars and they pull up the rear organizers to look(or preferably, the Toyota parts catalog is updated so we can see if there's parts commonality in the organizers).
    Trollbait likes this.
  4. Gokhan
    6,717
    2,672
    Paramount CA
    Toyota does not print superfluous information in their owner's manuals. If the owner's manual says there is a temporary spare, there is a temporary spare—no ifs and buts.
  5. Name Cannot Be Changed
    United States
    A temporary spare is useless if you have a flat 100+ miles from the nearest tire shop.
  6. Hammersmith
    2,497
    2,562
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Like I said, the odds are that the LE will come with a spare, but the manual doesn't say "Temporary Spare (equipped on LE)" or something like that, it says "Spare tire & tools (if equipped)". And the most recently updated information(the trim comparison chart on Toyota.com) says all three trims come with the tire repair kit and not a spare. My gut says the chart is likely in error and the LE does comes with a spare like the November press release says, but I also acknowledge that we are in strange times in regards to supply chains and that decisions can change at the last minute on things like minor options on brand new models. IMO, there's still enough uncertainty on the issue to not make a declarative statement like, "the LE definitely comes with a spare, no ifs or buts."
    Check for yourself. Go to this page and scroll down to Tires and expand.
    https://www.toyota.com/prius/features/mpg_other_price/1223/1225/1227
    Mendel Leisk and Gokhan like this.
  7. Gokhan
    6,717
    2,672
    Paramount CA
    Ah, OK, if there is a supply-chain issue, it should be an easy upgrade later for those who prefer a temporary spare, as the holes should already be there for at least the LE/SE.
  8. Trollbait
    12,832
    Is Toyota selling other cars with those tire sizes? Any other make doing so? At the rate Toyota expects to sell the new Prius at, a plethora of options in a year is unlikely if the answer to those questions is no. Now, I do think more options will show than did for the i3.
  9. Gokhan
    6,717
    2,672
    Paramount CA
    It is trivial for tire manufacturers to make a tire of a different size. It is as simple as reprogramming the machine. They will do so.
  10. Trollbait
    12,832
    What? No, it requires a new mold for the tire size. Now, there already factory lines already making the tire size. But Toyota is talking about selling just 35k in the US. That isn't exactly numbers to get tire companies to rush product to market.
  11. Gokhan
    6,717
    2,672
    Paramount CA
    …, which can be done by reprogramming the machine that makes the mold these days.
    I hope they would only sell 35; then, I would be the only one driving one around here. ;)
  12. Name Cannot Be Changed
    United States
    The 2023 Prius LE tire information is starting to shape up. wheel-size d0t com is now showing the oem specs:
    Tire size: 195/60 R17 on a 6.5Jx17 wheel with offset of 40
    and Yokohama has announced it will be providing the tires: Yokohama BluEarth-FE AE30
    You can find the announcement in Yokohama's online press room.
    For the higher trims, the specs are:
    195/50 R19 6.5x19 ET40 and according to Yokohama the 19s will be BluEarth-GT AE51
    I like to run All Weather (3PMS) tires, and currently the nearest compatible tires I see are 205/55 R17, such as Michelin Crossclimate 2 and Vredestein Quatrac Pro. In Crossclimate vs. Quatrac, the Crossclimate has better rolling resistance (according to some reviews), but I don't know how the Crossclimate compares to the oem Yokohamas since they're different sizes. Both carry an EU "B" rating for fuel efficiency, so the Crossclimates could be a decent choice. *I've read that a 10% reduction in rolling resistance adds 1% improvement in fuel economy.
    All that said, I'm not a fan of directional tires because of the tire rotation issue, as well as having a mounted spare tire that can only be mounted on one side of the car.
    Gokhan likes this.
  13. Name Cannot Be Changed
    United States
    One of the reviews I read was apparently incorrect. The OEM Yokohama BluEarth-FE AE30 with improved rolling efficiency has an "A" grade per the EU.
  14. bisco
    52,891
    why is that?
    Gokhan, Trollbait and Mendel Leisk like this.
  15. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,576
    2,605
    Taylors, SC
    I never trust "donut" temporary spares. Even when I have a temporary spare, on long trips, I carry a full sized one.
    I bought a full size wheel from a salvager not more than 6 months after I got my 2012 Prius v, the first year the model came out. It was in like new condition.
    It is more likely that full sized wheels will be more likely available than temporary spares, if they are of a unique size. Each car comes with four wheels, and not all cars come with a compact spare.
    Age doesn't affect a tire sequestered inside a car as one exposed to the outside environment. I'm sure the unused spare inside the car will likely be still usable for more than 10 years.
  16. Trollbait
    12,832
    Pressuring a tire on a wheel starts its service life. A tire inside a car has some protection from the elements, so it will have a longer service life than those installed on the car. Going past 10 years is pushing it though.
  17. Mendel Leisk
    42,373
    Still, how many here have ever replaced a spare, one that’s not seen more than sporadic (if any) use?
    Our cars build date was August 2009; I’m not intending to change it soon.
    I could be swayed though; i’ll be replacing snows next fall, maybe should ask them about spare longevity.
    Addendum: Google sided with “replacement by 10 years, or after use”. Still, I’d suspect a survey would find hardly anyone following this. That doesn’t make it right though; the right course is not always the most popular. Hmm…
    #37 Mendel Leisk, Feb 2, 2023
    GuyLR likes this.
  18. Nntw
    Nntw Active Member
    398
    248
    Toronto
    2023 Prius Prime
    Actually, my experience has been that this is not the case.
    Toyota will mention all the possible options and configurations... and then provide a disclaimer that not all features are found in all models.
    My 2021 RA4 manual talks about the TPMS system.
    Heck, even the French Canadian owner's manual talks about TPMS.
    Despite the fact that Canadian cars don't have it.
  19. JoeBlack
    JoeBlack Member
    112
    89
    Europe
    2021 Prius PHV
    Could you please share a link? Every EU sticker I found for BluEarth-GT AE51 or BluEarth-FE AE30 was marked as B for efficiency - at best.
  20. PaulDM
    PaulDM Active Member
    616
    320
    UK
    2022 Prius
    Excel
    Each rating represents a reduction of 3-4%. So a B rated tyre would reduce a consumption of 50mpg (for example) by 2MPG
    i changed my tyres from A rated to B and accepted the hit as the Wet Distance rating went from C to A
    i much prefer a shorted stopping distance by 5 meters than a loss of 2mpg tbh. But thats me.
    Bob P. likes this.
